11-09-2010, 07:16 PM   #16
DanielT74's Avatar
I see! Yes, I've just had a look at the old K-mount Vivitar I have in my office and a Leica mount and the Leica is definitely thicker (by about 1.5mm!). I don't have a Leitax mount nearby but I assume they are not as thick as the Leica (will check when I go home) to keep the distance to the sensor/film place the same, if I understand you correctly (sorry if I am slow here).
So this might give the summilux the space it needs... hopefully
11-14-2010, 06:54 PM   #17
DanielT74's Avatar
Woohoo!!! It is here and it cleared the mirror!
I did put the camera in sensor clean mode with the mirror up first to be safe(r) and when after turning off and on there were no strange clanks, shot a couple of pics. All OK so far!
Will do some (kind of) serious testing shortly and report. In the meantime, here's a pic of the beast itself (it is the size of A*85/1.4 and heavier!):
11-14-2010, 07:09 PM   #18
falconeye's Avatar
That's some serious lens p0rn
Glad it worked. How much did you pay?
Did you do the K mount conversion or did you find it in K mount?
11-14-2010, 07:21 PM   #19
DanielT74's Avatar
Thanks!
I just converted it using Leitax mount and instructions (works like Summilux 50mm and no sawing/filing required). An average person would take about 5-10 minutes to do this.
(I took about 20). But luckily this time I didn't drop my tiny little screwdriver on the rear element (which I did with my first Leitax conversion and amazingly it didn't damage it!)
As for the price I'd rather not say at this stage. But as you can tell it's well used and so it was cheaper than the typical $2300 mark. But I did get a nice Heliopan UV filter with it.
11-14-2010, 07:28 PM   #20
falconeye's Avatar
QuoteOriginally posted by DanielT74 Quote
(I took about 20)..
So, you're above average!
For the price, I can understand you don't want to disclose. But thank you for giving me some indication. So, R glass must be of similiar quality to M glass.
I'll watch out for it. Being in Germany, I may run into the occasional ... occasion :ugh:
Just around the corner is a retail store which has a used glass department with plenty of Leica glass...
11-14-2010, 07:39 PM   #21
DanielT74's Avatar
I imagine in Germany there is a lot more Leica to be found, so good luck with your bargain hunt!
As for R to M comparisons, from what I've read over the past few months, Summilux-R 35mm compared very well even to the more modern aspherical M-version (according to Leica guru Erwin Puts). As for other older glass it varies, Summilux-R 50mm is left behind by the aspherical M glass as is the Summicron-R 90mm (although some people prefer the dreaminess and rendition of the older version). This you understand is just from reading. I've never owned M lenses and only owned R lenses for a few months.
k-5, k-mount, mirror, pentax lens, question, question for owners, slr lens
To all k7 owners about mirror blackout times PinarelloOnly Pentax DSLR Discussion 2 10-09-2010 07:48 AM
Question for K-X owners. dimebagdave Pentax DSLR Discussion 6 04-29-2010 05:17 AM
PZ-1P question(for owners) LongLiveVelvia Pentax Film SLR Discussion 3 10-09-2009 10:51 AM
A question for K7 owners dafiryde Pentax DSLR Discussion 26 09-05-2009 02:52 AM
Question for people with SMC Pentax-DA 55-300mm F4-5.8 ED ChrisN Pentax SLR Lens Discussion 10 09-16-2008 10:10 AM
All times are GMT -7. The time now is 10:35 AM. | See also: NikonForums.com, part of our network of photo forums!
