Originally posted by K-9 That is of course, unless you're a lens licker. Thankfully, I kicked that habit a while back.
What, you don't eat off red Fiestaware?
Fiesta Ware (ca. 1930s)
Red Fiestaware, with a radiation rate of _20_ mrad/hr (20x that of Takumars -- plus you EAT OFF IT!), if you ate off it every day, is estimated to result in the consumption of .21 grams of uranium per year resulting in a dose of 40mrem per year. (Note that rem is like rad, only adjusted for how bad the particular kind of radiation is to humans. Not all radiation is created equal.)
The safety limit for humans is 5000 mrem per year. A single CT scan, which I had earlier this year, delivers a whopping 1200 mrem in one go.
Just for comparison, SMOKING a pack a day is estimated to deliver somewhere between 2000-5000 mrem per year.
So, considering that the lens is 1/20 what the dinnerplate is, I wouldn't worry too much. Just don't leave the lens in your pocket next to your testicles for 5 years running, ok?
As to electronics, if you can deliver about 5000 rads over a few minutes you can do long term damage, or if you exceed around 1Mrad. Since the lenses are 1mRad (1/1000 of a rad) in an hour, I don't think the camera will notice.
Put another way, background radiation is about 300 mrad per year, or about 1 mrad per day. So when your finger is touching the lens (What are you doing cleaning a lens with your finger?!), you are getting about 25x the rate as when you are not touching the lens.
Also, the rate of exposure is an important consideration. Your DNA has the ability to repair itself when damaged, if the damage is not too extensive. If you break off a single base, a repair molecule comes along and replaces it using the base's pair (each point on the DNA has a pair of bases) as a reference. Then the DNA is as good as new. If the rate of exposure is higher than the rate of your cells ability to repair themselves, or if you just get unlucky and get a full break, THEN you have a problem. If you received your entire lifetime dose of radiation all in half a second you'd probably be in a serious world of hurt, even though that same dose spread out is unlikely to cause problems.
The major danger from these lenses is not from using them, but from breaking them and then inhaling or ingesting radioactive dust. Don't do that. Now you are asking for trouble. The people who smashed the Takumar as a way to "fix" the lens were doing something stupid. I hope they didn't breath in too much of the resulting junk.
http://www.hermes.net.au/bayling/repair.html step 3 = NO NO!
