Originally posted by JustShane I don't mind the crop factor. It's FAR from useless. (IMO.)
I meant, useless if you expect to use it as you would in 35mm. In my K-x the 50mm gives such a different FOV that I don't even use it as much as a 28mm. Of course, it all boils down to what works for you.
Originally posted by JustShane Nikon and Sony also have a cheapy 50, so I'm a bit shocked Pentax didn't throw one in there as well...
Both Nikon and Sony make full frame cameras. Pentax line is APS-C exclusively, so don't expect seeing them release a fifty. The 35mm is the new fifty in digtal.
Quote: Granted, manual focus opens me up to sub-$100 pricing anyway.
(And truth be told, the AF ability on that Canon lens was quite pathetic. My best shots were usually Manual anyway.)
Hmm.
Decisions. :ugh:
You can literally collect fifties if you are willing to buy the M or A. Even then, the FAs are still a great choice and can be obtained for not much more.
From experience though, if you're after a walk-around prime, you should acquire something in the 28-35mm range which will see more use in APS-C than a fifty.
