11-14-2010, 05:36 PM   #1
s.randy's Avatar
SMC M 50mm f1.7 on K-x
OK, how do I use this lens with flash indoors???
11-14-2010, 05:43 PM   #2
What kind of flash? With the built in flash you're probably going to have to shoot at 1/180 sec and stop the lens way down. If you have an external flash that has auto setting, set your aperture and ISO on the flash and it should be about right (remember to change the Aperture on the flash when you do on the lens). If you have an external flash that you can control the output manually, try half power, one quarter power, etc and see what works.
11-14-2010, 05:47 PM   #3
s.randy's Avatar
QuoteOriginally posted by JeffJS Quote
Built in flash...
I tried going faster than 1/180 pretty much white'd out still.
11-14-2010, 05:53 PM - 1 Like   #4
QuoteOriginally posted by s.randy Quote
Built in flash...
Try these:
M mode (must be M, NOT Av or any other)
f=22 or 18
Manual ISO @200
Shutter speed @max (1/180)
Should be OK.
11-14-2010, 05:59 PM   #5
s.randy's Avatar
QuoteOriginally posted by ultraviolet Quote
Try these:
f=22 or 18
Manual ISO @200
Should be OK.
With the ISO around 400-800 this worked out pretty well. I think I am on the right path now. Thanks!
11-14-2010, 06:39 PM   #6
Just to point it out, unless you're using an external capable of High Speed Sync (HSS), you cannot go faster than 1/180 with the shutter speed. With HSS, you can go as fast as you see fit.
It's all workable though, you're on track to figuring it out.. Good luck.
11-14-2010, 07:00 PM   #7
s.randy's Avatar
Thanks for the help!
50mm f1.7, k-mount, pentax lens, slr lens, smc m 50mm
For Sale - Sold: SMC 85mm f/2.2 Soft, SMC-M 50mm f/4 Macro, SMC-M 135 3.5, SMC-M 85mm 2, SMC-M jgmankos Sold Items 3 06-14-2010 06:48 PM
For Sale - Sold: K-mount Tamron-F 2x Pz-AF BBAR MC7 TC, TWO 50mm SMC-M F1.4, and a 50mm SMC-A F pxpaulx Sold Items 11 06-14-2010 07:42 AM
For Sale - Sold: SMC 50mm, SMC 50mm, Tokina RMC 28mm bri_n_m Sold Items 3 06-20-2009 12:27 AM
All times are GMT -7. The time now is 10:40 PM. | See also: NikonForums.com, part of our network of photo forums!
