11-18-2010, 07:26 AM   #1
altopiet's Avatar
Info needed on CUNOR lens
Hi. I came across this lens today "CUNOR TELEPHOTO LENS 1:4.5 f=200mm No. H48076. As you can see it has an adapter (about 46mm to 42mm) I put it on my camera using my 42mm mount T-PK.
The problem that I have is that it only focus between about 2 and 4 meters. The shot of the leaf was at about 4m from the camera, everything else, up to and including infinity, is completely out of focus?
11-18-2010, 07:42 AM   #2
blende8's Avatar
Ok, obvious question:
What appears if you remove the adapter?
11-18-2010, 08:15 AM   #3
altopiet's Avatar
Hi Wieland. It seems as if it was meant to be for an original screw mount of about 46mm. The silver adapter brings it down to 42mm. I have no idea for what camera it was originally used. Is it possible that the 2 adapters, will have a sort of "extension tube" effect, and that it is the reason for the limited focus distance?
11-18-2010, 08:18 AM - 1 Like   #4
Tokina-made. Yes, the no-infinity problem is due to the added thickness of ~46-42mm adapter.
ref:
the many brand names: Manual Focus Lenses :: View topic - Lentar (Tokina?) 200/4.5 preset - another lens of many names
adapter info: Manual Focus Lenses :: View topic - Tele Tokina 4.5/200mm Tokyo Koki
11-18-2010, 08:34 AM   #5
altopiet's Avatar
Thanks rhodopsin, it was what I was looking for, and suspected. Thanks both of you for your time
11-18-2010, 09:17 AM   #6
blende8's Avatar
I am no expert in this, but it could be that this is a T-mount lens.
You then need a T-mount adapter.
11-19-2010, 12:22 AM   #7
altopiet's Avatar
Thanks Wieland
camera, focus, k-mount, lens, pentax lens, slr lens
Info on Lenses needed - F2.8 120mm, F3.5 28 mm wide angle Pentax, etc. SweetSherri Pentax SLR Lens Discussion 19 07-19-2010 09:13 PM
Info on the new DA L Lens's ? vk4akp Pentax News and Rumors 53 09-24-2009 12:48 AM
Tamron 35-90mm F4-5.6 AF Info Needed! Ballyclogh Pentax SLR Lens Discussion 0 06-09-2008 09:05 AM
Info about lens Mikhail Pentax SLR Lens Discussion 0 05-12-2008 05:06 PM
Info needed Donquichotte Pentax SLR Lens Discussion 2 12-02-2007 03:13 PM
All times are GMT -7. The time now is 11:48 PM. | See also: NikonForums.com, part of our network of photo forums!
