11-26-2010, 11:57 AM   #16
success!
Mirror trimming is not necessary.
The way the lens is currently set, infinity focus is achieved at a setting on the lens at right below 2m which leaves plenty of room for the mirror. The mirror starts to tag the back of the lens when set to about 3m.
I will adjust the focus ring properly once it is not super cloudy out and also may want to use a tripod to help zero in what i need to set it at.
The aperature ring is currently being held in place with a stranded wire stuck in the channel where the original spacer used to go. If the m42 adapter was just a little bit bigger around it would be a perfect fit. I eventually may end up making a spring metal type thing to hold the aperature ring in place.
I also need to find/make something to extend the aperature linkage arm so I can use stop down metering. Ithink I have the m42 adapter mounted in the correct place for the metering to work - I used a k-mount lens as a guide for the positioning.
For right now, here are some pics of the lens itself. I will post pics from the lens once I am able to get some good ones.... maybe this Saturday.
11-26-2010, 12:34 PM   #17
Just thought of something. I might be able to add the spacer back in and get rid of the wire. I'll have to try it out and see how it works.
50mm, 58mm, condition, k-mount, lenses, pentax lens, rokkor, slr lens
For Sale - Sold: Minolta X-700 + Rokkor-X 50mm f/1.7 + extra focusing screen deadwolfbones Sold Items 9 11-19-2009 01:11 PM
S-M-C 1,4/50 vs. Rokkor PG 1,4/58 estudleon Pentax SLR Lens Discussion 0 10-11-2009 08:28 AM
For Sale - Sold: Minolta Rokkor 85mm f/1.7 Fast Portrait Lens converted to M42 Mount wallyb Sold Items 6 02-26-2009 10:55 AM
All times are GMT -7. The time now is 09:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
