11-19-2010, 08:05 PM   #1
wrconley's Avatar
What kind of lens mount is this
I bought a Kalimar 35-70mm lens which was suppose to have a K-mount. When I got the lens it would not fit on my K-7. The raised ridge on the back runs about 1/3 of the circumference. I see K-mount run about 1/6 of the circumference. Can I put an adapter on this or give up and sell it. It's like new. Picture attached. Any help would be appreciated. I think it's a K-AR whatever that is.
11-19-2010, 08:14 PM   #2
P/K A, R(icoh) P/K
11-19-2010, 08:52 PM   #3
If it is that ridge that is making it not fit, you should be able to remove that whole black piece with the ridge to make sure it will fit. If so, you can always then trim the ridge down to proper length so it won't interfere.
Edit: Forgot something.... there might be an extra pin on that lens mount that is catching on the auto focus of the camera. Take a pic of the whole lens mount and post it. If it has that extra pin, that may be all that needs to be removed to make it work with your camera.
11-20-2010, 04:46 PM   #4
It's very likely that that big shroud around the aperture lever is blocking the lens from mounting on your dSLR. You need to remove the flange from the lens and grind it down with a Dremel tool or the like. Spritz it with flat black paint and remount it, should be fine. I have done several lenses like that.
11-20-2010, 06:46 PM   #5
boriscleto's Avatar
Just use a JIS screwdriver to remove the 2 screws from the black piece. No need to replace it.
11-20-2010, 09:37 PM   #6
wrconley's Avatar
thanks
I just can't get myself to grind off that ridge, just yet. It's a brand new lens and I really would like to use it but cutting it off worries me.
11-21-2010, 02:23 AM   #7
That ridge may just have saved your camera! If this lens is compatible with Ricoh P-mode cameras (and it certainly seems that way), then there will be a small pin diametrically opposite the red dot (i.e. out of shot in your picture). This can get jammed in the AF-drive part of the camera's mount, and you would then be in deep er, waters.
When you decide to get rid of the ridge, do ensure that you remove the dreaded pin first (it's easy, just remove the back plate).
11-21-2010, 07:36 PM   #8
wrconley's Avatar
Thanks
Thanks for all your comments but I'm afraid of the electrical contacts shorting out or the pin (actually, it looks like a ball not a pin). It's not worth the chance of destroying the K-7 which I love. I think I'll put in on eBay for $20 and just forget it. Pity, it's like brand new.
k-mount, lens, pentax lens, slr lens
A new kind of single lens reflex camera falconeye Non-Pentax Cameras: Canon, Nikon, etc. 22 01-16-2011 08:17 AM
Need help to identify lens, which kind of mount? cofra Pentax SLR Lens Discussion 2 08-10-2010 03:27 PM
max lens mount/tripod mount weight soycory Pentax DSLR Discussion 1 10-28-2009 12:38 PM
Q about fisheye lens attachments (the cheap kind) mirateck Pentax DSLR Discussion 6 07-15-2008 06:01 AM
What kind of Vivatar lens is a P/KA mount? Eastern Shore Charlie Pentax SLR Lens Discussion 4 04-17-2007 10:27 PM
All times are GMT -7. The time now is 06:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
