Originally posted by kyteflyer Does anyone have any strong recommendations either way? Would it be too much to ask to say why, and to post examples? I've looked on the PPG but all the shots are so good, its difficult to really work out which would be the better choice.
Ah ha! I think you nailed it. I don't think you need primes for the best image quality... the difference is much much less noticeable than a while back. In addition, a good zoom costs less than the coupe good autofocus primes it would take to fill the void. There are other good reasons to choose primes (I'm a prime guy, myself).
While the limiteds might be nicer than the 16-45... add up the cost of the 15, 21, and 40... yikes! The 16-45 is not a whole lot slower, and you can always fill in the gaps with primes later on as you *see the need* which is important. I can attest that the prime option leads to higher IQ in situations where you will actually notice the difference, but for your needs and budget, I the zoom would serve you well over a single LTD or a bunch of manual focus primes. If you are happy with your results... don't listen to any of us
For you, I would buy the 16-45 for the wide angles and increase in image sharpness over the kit, and then a manual focus 50mm 1.7 or 55mm 1.8 (my nod is to the 55) because they are dirt cheap (50 dollars, should be anyways) will open the fast aperture door wide open. You don't need an adapter to use those lenses (the 55 is available in k mount), and while they are more finicky than an autofocus zoom, it's nice to have the option.
The limiteds are quite special (as you know) but I believe should be selected for ergonomics and IQ... not on the basis of IQ alone. The size of them is what makes them extra special (in my book).
