11-20-2010, 11:52 AM   #1
TexasLangGenius's Avatar
Vivitar PK-AR Lens: Dangerous to use on my K-x?
Hello everyone,
The delay of the delivery of my K-x might be a blessing in disguise, for it seems to me that I would have had to have shelled out a huge amount of money to get it repaired had it gotten stuck because of a Ricoh pin.
Here are some pictures of the lens. Tell me what you think.
Thanks,
TexasLangGenius
Canon PowerShot A620  Photo
11-20-2010, 12:18 PM   #2
This sure looks like the sticky version of the Ricoh pin: pointed and protruding enough to catch in the AF drive slot.
11-20-2010, 12:34 PM   #3
QuoteOriginally posted by jolepp Quote
Yes. I'd try to carefully remove the screws securing the silver colored bayonet base, remove the base, remove the offending pin, and replace the bayonet base.
Dave
PS maybe you can glue it down or cut it off with a Dremel tool, but I'd try the above first.
11-20-2010, 12:38 PM   #4
Otis Memorial Pentaxian
Yes, that is the dangerous version of the pin. You are lucky to have spotted it in time! Removal should be pretty straightforward. Good luck!
11-20-2010, 11:06 PM   #5
Here are some higher resolution shots of the mount.
So the one on the left (the big, pointy one) is the Ricoh pin, right? I suppose the other one is the Pentax contact, so I can leave that one in. I just want to be sure.
11-20-2010, 11:53 PM   #6
Yes. The pointy one on the left is the Ricoh pin. Be sure to keep the other so that auto modes work.
11-21-2010, 06:04 PM   #7
Offending pin removed. It took me only three minutes to do it, too.
11-21-2010, 06:23 PM   #8
QuoteOriginally posted by TexasLangGenius Quote
How did you do it?
11-21-2010, 06:42 PM   #9
All I did was take my miniature screwdriver, undo the screws on the mount, and lift up a tiny metal plate. It was so easy.
I removed the screws on the outer silver rim, not the ones in the inner black rim.
k-mount, lens, pentax lens, slr lens
Dangerous third party lenses (PK-A/R)? MNCurt-K10D Pentax DSLR Discussion 13 07-30-2013 12:48 AM
Misc My big dangerous cat miss_alexx Post Your Photos! 14 11-18-2010 11:32 AM
Dangerous beauty dexmus Monthly Photo Contests 0 10-10-2010 09:07 AM
Walking into Adorama can be dangerous NaClH2O General Talk 20 03-26-2008 09:26 AM
is light snow and rain really dangerous? Gooshin Photographic Technique 26 01-13-2008 08:37 PM
All times are GMT -7. The time now is 02:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
