Originally posted by JACOBY I was given a couple lenses a suntar 35mm f2.8 screw mount and a super albinar 28mm f2.8 they are both auto lenses and real good shape and clean. I know they are not as good as my pentax guys but for free. anyway is there a way to stop down metering with these. My camera is the K100d a real beautysold my d3000 for this camera for the fact I can use some of my old pentax glass Thank You Sorry for the long post
there is a modification you can do to the lens, to make it work in stopped down mode. Youo need to block the actuating pin in the depressed position.
see the modification below done to an adaptall auto mount.
I use a small cut spacer from the end of a ball point pen refil, put a slit lengthwise to allow easier instalation if you can't take the rear mount off.
