Originally posted by Balisarda Hello all,
I'd very much like to try some grand old Pentax K, M, and A lenses on a K20D, but before I spend any money I'd like to know if Pentax's DSLR bodies will support open-aperture metering with those old lenses.
(I already surmise I'll have to use Manual mode with most of those lenses, which is fine. I also surmise Aperture Priority mode will work the Pentax-A lenses, right?)
My sincere thanks,
Eric.
the metering is not fully automatic with all lenses.
For A lenses there is no issue at all, you can shoot them in any mode on the camera and they will behave just like modern lenses (Less autofocus of course)
For K and M lenses, you need to meter using one of the manual metering methods. these are the green button, and using the DOF preview. the difference between the methods is as follows.
- The green button stops the lens down for about 1/2 to 1 second, at which time it meters, and then the lens opens up again. When it meters, it sets the shutter speed to match the light coming through the aperture. Using DOF preview stops the lens down, and activates the metering and you can
- read the over or under exposure in the viewfinder, but it does not change the camera settings.
as you can see, not true open aperture metering.
Additionally, you should be aware that there is an issue with the focusing screen in the K20 (also used in the K10) which leads to significant exposure errors at some apertures.
I have posted the attached chart before,
