11-24-2010, 11:37 PM   #1
jaieger's Avatar
DA15mm Lens Cap
Just wondering - is it safe to put regular clip-on lens caps on the DA15 ? I just got it and, like on the DA40, hate the screw-in cap, but I'm a bit paranoid that it'll touch the front element, which does seem to curve outwards a bit.
11-24-2010, 11:50 PM   #2
paperbag846's Avatar
Maybe you could throw a filter on the lens for non-critical use?
11-24-2010, 11:57 PM   #3
I have a hunch that it'll touch, but you should try it and find out - it's not going to cause any damage if you're gentle about it.
11-25-2010, 05:45 AM   #4
I've been using a generic clip on cap on my 15 for several months now with absolutely no problems. Only the outer edge of the cap extends below the filter threads, the rest is recessed. The front element of course does not extend beyond the threads, or using filters would be impossible.
I also did an experiment to prove that it does not touch: breathe a bit of condensation onto the front element, and quickly cap it before it evaporates. Then turn the cap. Take it off and see if anything has been traced into the condensation. Mine shows nothing.
I seriously doubt it's even possible to scratch the glass with plastic. Glass is very hard, and only harder substances can scratch it, like hardened steel or sand. Plastic is pretty soft in comparison.
11-25-2010, 06:07 PM   #5
JHD
The metal screw on cap is a joke. I took mine off and promptly bought a snap on cap.
11-25-2010, 08:03 PM   #6
Hi, I can guarantee that newer 49mm cap (O-LC49) works perfectly without any scratch on front lens element. Easy-grab design makes this cap very easy to remove compare to the old 49mm cap.
11-25-2010, 11:24 PM   #7
NeverSatisfied's Avatar
QuoteOriginally posted by JHD Quote
Well, the metal screw-on cap is nicely crafted and quite secure, but a bit more troublesome to use. I'm keeping mine in the original box and am now using the standard 49mm Pentax clip-on cap (like the kind that comes on the FA 50, etc.), with no problem.
bit, cap, k-mount, lens, pentax lens, slr lens
Lost lens cap on 18-55mm DA L. Can anyone confirm if this eBay cap is the correct one philthy Pentax SLR Lens Discussion 3 10-15-2009 01:26 AM
All times are GMT -7. The time now is 09:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
