11-25-2010, 08:10 PM   #1
Help please - is this lens K-mount?
Hi, I'm trying to identify the mount for the a lens (pictures attached). I *think* it's a k-mount, but I'm really not sure.
Can anyone help me out?
11-25-2010, 08:17 PM   #2
jatrax's Avatar
It certainly looks like it. Take a look here for a good article on various mounts:
It also looks like it has the big shield on the bottom. Some off brand lenses have these a little too big to work on modern digital cameras although they work fine on film ones.
11-25-2010, 08:27 PM   #3
macTak's Avatar
Agreed--it would need to be filed down for use on a Pentax DSLR probably. It also looks to me like the the aperture lever is somewhat bent; I can't tell if it would be a problem or not.
11-25-2010, 08:37 PM   #4
Right, thanks for that.
I guess you'd need to pull the mount apart in order to file it down, has anyone had any success in doing that?
11-25-2010, 09:32 PM   #5
Steinback's Avatar
That looks like a Vivitar Series 1 70-210mm f/3.5 (Version 1)? I believe that there are 3 screws around the circumference of the mount between the 3 K mount fins that lock into the camera and the flange that sits flush to the camera body. If I'm remembering correctly then loosening those screws should allow you to remove the aperture shield so that it can be cut down safely.
I agree that the aperture lever is bent and will almost certainly have to be straightened to work correctly. Be careful with cleaning the rear lens element; it seems to be very dirty.
k-mount, lens, pentax lens, slr lens
K-x lens mount with old k-mount lenses sipper Troubleshooting and Beginner Help 9 03-18-2010 05:45 PM
Lens mount can use with Pentax mount espanola Pentax SLR Lens Discussion 13 02-24-2010 04:48 PM
max lens mount/tripod mount weight soycory Pentax DSLR Discussion 1 10-28-2009 12:38 PM
Is it possible to mount an old CCTV C mount lens to my k20d? WiseOx Pentax SLR Lens Discussion 2 07-15-2009 03:01 PM
Change vivitar FD mount lens to K mount? meszidik Pentax SLR Lens Discussion 4 09-12-2008 09:59 AM
All times are GMT -7. The time now is 12:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
