11-26-2010, 08:14 AM   #1
DA* Zoom Lens Quality Question
Just getting into Pentax after being a long time Canon & Nikon user. Am impressed so far but need to 'calibrate' my expectations on Pentax quality. I've sent back one DA* 16-50mm because of a focus problem: would heavily back focus at the wide end only and using the AF adjust would only make it (heavily) front focus at 50mm.
The replacement I have now seems okay for focus, but the image shifts left and right when changing zoom direction - shifts a lot! Especially noticeable from 35-50mm, and I've never seen this in a zoom lens before. The other 16-50mm did not do this (checked before it was returned). And the kit 18-55mm is fine with no shift.
Should not affect still photos unless it loosens up over time - which is really my main concern - and I want to deal with it now rather than later. (Also looks quite annoying when using video...).
Can other DA* owners check to see they have this shift? Just zoom one direction then note when you change zoom direction does the image shift left/right?
Not saying it's an issue. And I'm very happy with the DA Limited primes and K5. Trying to understand what are normal characteristics for a Pentax zoom. Canon drove me crazy with focus issues from lens to lens; some great, some not.
RK
11-26-2010, 08:39 AM   #2
With my DA*16-50mm image doesn't shift at all.
You should send your copy back, again :s
11-26-2010, 09:47 AM   #3
blackcloudbrew's Avatar
Never had any focus/shift problems with that lens. It's the best I own and use. Send it back though. This shift problem is one I've never seen anyone describe or post on. It's got to be rare.
11-26-2010, 09:50 AM   #4
Thanks for the quick replies - it's going back...
11-26-2010, 01:26 PM   #5
Ash
Community Manager
Ash's Avatar
First I've heard also - the 16-50 should be rock solid in this regard.
All the best for the repair/replacement.
12-18-2010, 07:38 AM   #6
16-50mm zoom gets a bit stuck
Hi, regarding bad copies of the da* 16-50mm, just got mine, and the zoom gets gritty at about 28mm focal length, much more evident when going from high to low focal lengths. Is this a bad copy, or common for this lens.
12-18-2010, 08:21 AM   #7
@ajperumbeti: You've got a bad copy. My 16-50 is completely smooth throughout the zoom range.
12-18-2010, 02:11 PM   #8
Number for DA* 16-50mm im returning
Thanks for the info on smoothness of zoom control. I guess, ill try and return this copy. The number is 9045278
12-18-2010, 03:08 PM   #9
Because of the design there should be a hiccup at 28mm. 16-28 range should be smooth and easy, 28-50 should be smooth but be a little harder to turn. It gets worse if you point the lens up. It shouldn't be "gritty", but you should feel the transition
12-18-2010, 05:06 PM   #10
Ash
Community Manager
Ash's Avatar
Not so sure about any 'hiccup' - perhaps more like a smooth transition between easy turning and more firm tightness to the zoom ring. The motion should be seamless through the 28mm mark.
16-50mm, da*, direction, focus, k-mount, lens, lens quality, pentax, pentax lens, shift, shifts, slr lens
Question for K-5 owners: LV zoom-in quality? photogerald Pentax K-5 23 10-30-2010 03:53 PM
question about testing lens quality tbirdas Troubleshooting and Beginner Help 2 07-04-2010 10:21 AM
Long Zoom lens question HoBykoYan Pentax SLR Lens Discussion 10 06-30-2010 06:42 PM
Prime & Zoom Lens Question LadyRo Pentax SLR Lens Discussion 9 06-01-2010 06:34 PM
Finally a quality Zoom lens to match a prime Eastern Shore Charlie Pentax SLR Lens Discussion 2 08-20-2007 02:16 PM
All times are GMT -7. The time now is 01:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
