Originally posted by dupazbita any of these worth it? or can i get much better deals?
Pentax-M 50mm f1.7 £55
Pentax-A 50mm f1.7(with hoya skylight filter) £65
Pentax-A 50mm f2(with hoya skylight filter but no caps) £40
Pentax-FA 80-200mm f4.7-5.6 £35
Pentax-M Takumar 135mm f3.5(M42 mount) £55
Carl Zeiss Jena 135mm f3.5(PK mount) £65
Pentax-FA 100-300mm f4.5-5.6 £90
oh and il look out for the a 28 2.8 for sure! thanks
M 50/1.7 Fine lens, but you should be able to get it for 25-40 £ Numerous Pentax bodies was sold with this as kit lens.
A50/1.7 Same lens with A contacts. Apperture ring can break down due to plastic part inside it (the rest is metal). Mine still work after 26 years. Can be fixed. Price may be OK, but I could get it cheaper in Sweden.
A50/2 Better than its reputation, but the price is too high.
FA80-200 Avoid it. Best Pentax lenses (besides the expensive pro FA*) in this range are the M80-200/4.5 and the A70-210/4 (constant 4, make sure it says SMC Pentax on the lens, there is an uncoated version that is the same as the A Takumar, which is not such a good lens)
Pentax-M Takumar Does not exist. Seller is probably trying to get rid of a Takumar bayonet, which is both a simple 4-4 lens solution and does not have SMC. Alternatively, if it is a Pentax-M 135/3.5 (no Takumar), it is a nice and very compact lens and then the price is OK.
CZJ 135 Lens with good reputation, some say it has the best bookeh of all 135mm's. Simplified sonar solution.
Pentax-FA100-300. Avoid. See M80-200 and A70-210 above.
I am not that impressed by the M/A28/2.8 or the M28/3.5. One of the best 28mm's Pentax made is the K28/3.5, but it goes for a bit more. 70-120£. Incredibly sharp.
What I usually recommend as the best bang for the buck of Pentax made K mount lenses:
M50/1.7
K55/1.8
FA28-70/4 (constant 4). This is a really great lens optically though a bit plastic, but mine is still in one piece after 15 years.
