11-28-2010, 03:56 PM   #16
Ira
In general, you can't. The registration distance for M39 (LTM) is less than that for any SLR, so you give up infinity focus unless there is a correction lens built into the adapter (not good). The one exception is M39 (Zenit SLR). Those lenses have the same registration distance as M42 and Pentax-K.
Yep:
My 37mm MIR (39mm mount) with the M42 adapter doesn't give me infinity focus.
11-28-2010, 05:36 PM   #17
Here's my shiny friend... I haven't actually mounted it on a digital camera yet.
11-28-2010, 05:38 PM   #18
Blue's Avatar
Some of the Meyer wide angle and "normal" lenses are not only cool looking but decent performers as well, especially the Meyer 29/2.8. I have a "Zebra" Helios 58/2 sitting on my Contax D. I think I paid $15 for it.
11-30-2010, 04:58 AM   #19
RioRico's Avatar
Many Exakta-mount German lenses are bright shiny metal, and cheap, like the fat Meyer Primagon 35/4.5 in front of me right now. Here is how to adapt such a lens for a Pentax mount:
* Obtain a cheap Bower-type M42-PK adapter, a cheaper M39-M42 adapter ring, some Gorilla Glue, and a sheet of 300-grit sandpaper.
* Set the sandpaper on a very flat hard surface.
* Grind away the lens-side (wider) flange of the M42-PK adapter to remove ~0.8mm, leaving just a a razor-thin flange.
* Use VERY LITTLE Gorilla Glue to secure the M39-M42 adapter ring around the Exakta bayonet. [NOTE: Gorilla Glue expands by 4x-6x times. It can get ugly.] You may need to remove a stop screw from the lens base. Don't lose it, in case you ever want to dissolve the glue and return the lens to its Exakta state.
* After the glue dries, screw the M42-PK adapter onto the lens. Voila! You now have infinity focus.
Another bright shiny cheap metal lens: the tiny Enna Tele-Sandmar 100/4.5 for Argus C3 rf's, often obtainable for US$10-20. I am awaiting delivery of a 42-43mm stepup ring (US$4), which I am told allows the Sandmar to have infinity focus on a Pentax camera when glued correctly. Or, drill a hole in a Pentax body cap, and use Gorilla Glue to hold the lens in place in the body cap. Ah, with that lens, you'll love the old-timey look, eh?
chrome, k-mount, lens, pentax lens, slr lens
People Shiny Warped Post Your Photos! 4 06-07-2010 09:09 PM
Chrome Glorious Chrome UltraWide Post Your Photos! 9 08-23-2009 05:43 AM
Cheap manual lens on cheap extension tube with cheap flash! Also cats. pasipasi Post Your Photos! 12 08-28-2008 04:43 PM
cheap lenses vs expensive lenses WMBP Pentax DSLR Discussion 21 12-19-2006 11:08 AM
All times are GMT -7. The time now is 09:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
