11-27-2010, 09:49 PM   #1
Raybo's Avatar
Anyone here fix lenses?
Anyone here fix or have any experience with fixing lenses?
I have an M100 f4 "macro" that works fine except the aperture does not "click" on the f stops, it just turns smoothly like the focus ring.
I also have an M28 f3.5 with the aperture stuck solid on f8 and it will not budge.
Anyone willing to give them a shot? If not I will just let them sit until I get nerve to FUBAR them myself.
Ray
11-27-2010, 09:54 PM   #2
Canada_Rockies's Avatar
Have a search for Eric - he's actually on the forums occasionally. He fixes Pentax stuff. If you were in Canada, I would send you to Vintage Visuals in Calgary.
11-28-2010, 07:00 AM   #3
Get a quote from Eric:
Home
11-28-2010, 07:54 AM   #4
vievetrick's Avatar
Anyone know I he would work on a Sigma Pentax mount lens? I will email him as well but figured would ask here. Anyone, use him?
11-28-2010, 08:56 AM   #5
i'm not sure about the m100 macro but if I recall correctly on the other lens I have taken apart. If the aperture dial turns without clicks then the leaf/spring is not situated properly on the lens body. It should be a relatively easy fix if you know how to take it apart. Think of it like a battery terminal where they springs hold the battery in place. Which you turn the dial the spring pops out and then sits in the next groove. If the spring is deformed or moved then it is always open and doesn't click into the next groove those turns like the focus ring.
11-28-2010, 10:05 AM   #6
"Anyone know I he would work on a Sigma Pentax mount lens? I will email him as well but figured would ask here. Anyone, use him?"
I have not used him yet but I am in process of packing and sending him a Pentax 200mm F2.5 and a Tamron lens to remove a damaged haze filter. He is highly recommended by many users here. Lots of Pentax experience. If the lens has any substantial value I would suggest pro repair. I like to do it myself too but I have no lens tools or spares much less any experience doing it.
If the Sigma repair looks complex you might try going to Sigma repair direct. It is my 2nd hand understanding they are pretty good
11-28-2010, 02:42 PM   #7
wlachan's Avatar
Aperture ring w/o click means the ball bearing is missing underneath the ring. This can only happen because it was repaired before and the ball bearing flew away. No sure why the aperture stuck at f8 for the other lens but anything mechanical can be fixed.
11-29-2010, 09:12 AM   #8
gokenin's Avatar
I have had Eric do CLA on a couple of camera and had him work on several Taks and FA lens as well and have no problem recommending him.
aperture, k-mount, pentax lens, slr lens
Is there examples of how much to fix/replace the SDM on lenses? Reportage Pentax SLR Lens Discussion 6 04-28-2010 12:58 AM
Any fix for this? photolady95 Photo Critique 20 06-26-2009 07:23 PM
Ok, so what is this and how do I fix it? RickL Pentax DSLR Discussion 31 05-23-2009 08:27 PM
Can I fix this with PP MaKettle Digital Processing, Software, and Printing 8 04-29-2009 06:18 AM
how to fix my F 50 f/1.7 Bas.K Pentax SLR Lens Discussion 6 05-15-2008 05:54 AM
All times are GMT -7. The time now is 11:48 AM. | See also: NikonForums.com, part of our network of photo forums!
