11-29-2010, 08:36 PM   #16
Spock's Avatar
QuoteOriginally posted by thirdofthree Quote
I'll chime in as the lone supporter of your idea for an FA 28-105/3.2-4.5.
I will second that. The FA 28-105/3.2-4.5 is a great little lens - it's fairly fast and stopped down a bit it takes very satisfactory images.
When I travel light, all I take is the 28-105, the DA15 for wide angle shots and maybe my A28 F2 for low light.
11-29-2010, 09:05 PM   #17
paperbag846's Avatar
DA 70 would be a nice split from the 45 on your zoom.
K 55 1.8 would be a nice budget alternative. See if you can find the k-mount version. It's a nice focal length on digital (almost 85mm on film).
DA 15 could come last if you find you would value a dedicated wide angle, at which point you could safely sell the 16-45. That would be a nice and compact set up.
The 15 would not be necessary unless you find yourself really loving wide angle photography, because the zoom is no slouch at 16mm.
11-30-2010, 08:11 AM   #18
gazonk's Avatar
QuoteOriginally posted by amalongi Quote
I think I am going to add the DA70 and continue carrying the 16-45 for now. Perhaps next year, I will add the DA15.
Similar to my plan! (But before I add the DA15, I might add the 55-300 in order to have something longer than 70mm)
11-30-2010, 10:32 AM   #19
I use my 16-45mm 55-300mm combo and my 43mm for low light. I recently got the Tamron 28-105mm which I use if I don't want to have to change lens. It does a good job. Not as sharp as the others, but sharp enough.
11-30-2010, 02:42 PM   #20
May I suggest the Ef-s 17-85mm, oh wait, that Canon. How aboout the Ef 28-135mm, Ef-s 18-135mm EF-s 18-200mm, Ef 24-70mm L or the Ef 24-105mm L? Wait, those are Canon as well. Oh well, theres always Sigma.
11-30-2010, 03:08 PM   #21
QuoteOriginally posted by HeavyD Quote
I don't get it. ??
There are plenty of options in Pentaxland for the OP, especially considering light weight and small size is a priority.
12-02-2010, 04:54 AM   #22
gazonk's Avatar
I had a comment on this which was deleted during the server disaster, I'll phrase it differently this time:
I have never heard anything nice about that 17-85, it has been sold as a "better kit lens" with Canon bodies, but was never a good lens. The Pentax 17-70, for instance, is a much better lens. In fact, even the Canon 18-55 IS is better! dpreview's test shows that the 18-55 (IS version) is much better at the wide end, and better all the way up to 35mm, only above that the 17-85 gets better (and of course has longer range).
forum, k-mount, pentax lens, slr lens
Complement to my DA 35mm / 2.8 MACRO yoon395 Pentax SLR Lens Discussion 7 10-24-2010 01:08 PM
Pentax lenses to complement a DA 16-45mm RobG Pentax SLR Lens Discussion 22 01-16-2010 09:08 PM
Good complement to 18-55mm kit lens? jonathan1984 Pentax SLR Lens Discussion 22 12-14-2009 07:05 PM
Long prime to complement DA*50-135? Voitlander 180? David Whiteley Pentax SLR Lens Discussion 29 02-16-2009 03:37 PM
Best complement to DA40? ariahspam Pentax SLR Lens Discussion 11 06-18-2008 09:13 PM
All times are GMT -7. The time now is 02:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
