09-25-2007, 11:52 PM   #1
Weird Lens won't mount
So I bought a random cheap lens from KEH, but I can't get it to mount on my camera, it seems to have the same bayonet tabs as my other k-mount lenses but has a much larger wall thing inside of the apature lever (it is there for like 90 degrees of the lens).
It also has a P setting not an A setting and the mount is labeled R/K.
I think I'm just going to cover the back of the lens very well and dremel off the little wall (because I'm pretty sure that it is what is keeping the lens from mounting) but if its not even a k-mount lens than I should just send it back and get a refund.
09-26-2007, 01:25 AM   #2
rdc
So I dremeled it off, it works just fine now, although whatever P is its not A the lens only works in M mode.
It is a clever little lens, it has 4 rings, focus, zoom, f-stop, and macro.....the macro feature is literally a built in extension tube, all it does is slide the whole lens away from the camera, very smart it seems like more lenes could do this.
The other two rings are a little more annoying, it only stops down in whole stop steps (which matters sorta), and has a very short focus throw.....a little less than a quarter turn. Now I just have to see how it performs, at the very least its fast for an old zoom.....its a 2.5-3.5 35-70mm
09-26-2007, 03:38 AM   #3
Abbazz's Avatar
QuoteOriginally posted by rdc Quote
What are the zoom range, maximum aperture and brand of this lens? Could you please post a picture of it?
Cheers!
09-26-2007, 05:37 AM   #4
jeffkrol's Avatar
Looks to be a Ricoh/ K mount lens. P may be for program so be aware that there may be a small pin that jams up to the focus driveshaft and may make it hard to remove (you would probably have nooticed by now ). Some lenses have the flange in the way of the new design of the mirrorbox as you also found out. No big deal...
Bet it this one but in K mount......
PENTAX Screw Mount M42 35-70mm F2.5-3.5 Spotmatic DL MC - (eBay item 130143034213 end time Oct-11-07 16:38:33 PDT)
09-26-2007, 10:42 AM   #5
FotoPete's Avatar
Looks like a beauty! Makinon made a 24-50mm f3.5-4.5 of similar 4 ring control. It was dented and I couldn't quite justify purchasing it. It would look really nice on dslr though. It's mechnical presence would outimpress many of today's lenses. =P
09-26-2007, 01:03 PM   #6
rdc
jeff yup thats it, although mine is branded Access not Soligor
09-26-2007, 05:45 PM   #7
FotoPete's Avatar
It's great cuz you can macro up to 1:2.7
k-mount, lens, mount, pentax lens, slr lens, wall
weird screw mount 2x converter NicK10D Pentax SLR Lens Discussion 1 07-11-2010 04:11 AM
Weird 85mm lens vanchaz2002 Pentax SLR Lens Discussion 14 05-16-2010 04:39 PM
So who won the Lens off Ebay?? Fl_Gulfer Pentax SLR Lens Discussion 6 12-06-2009 08:56 PM
Weird Manual lens problem columbus Pentax SLR Lens Discussion 11 09-27-2009 02:00 PM
Ooops, won 2 135mm m42 lens, which one should I keep? reknelb Pentax SLR Lens Discussion 2 02-25-2007 11:12 AM
All times are GMT -7. The time now is 10:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
