Originally posted by elg JeffJS,
It still matters a little bit, as kit lens sometimes demonstrates similar effect at times (though this is occurring a lot less than with SMC F 35-70). It never happened with Sigma 28-135 IF though.
What's the reason for dragging aperture blades? Does it indicate that the lens will not last long?
Thanks,
elg (Erika)
Dragging blades can indicate oil on the blades or weak springs on the aperture mechanism. I doubt this would be the case with your kit lens but you can easily check it. Simply remove the lens from the camera and flick that little lever on the back. It should open the blades completely and snap right back when you release it. If your sigma has an A setting on the aperture ring (or no ring at all) you can compare the two and see the difference (if a ring and no A setting put it at f22 or whatever the highest number is). Except for wide open shots, a dragging aperture will not completely stop down during the exposure, causing overexposure.
Remember (or know now) that the camera does not stop the aperture down for metering unless you tell it to. It's a calculated exposure based on previous knowledge (by the designers) of how exposure metering works. That is, you tell the camera what aperture you want to use and based on that and the ISO setting, it will calculate the shutter speed.
Simple age can cause this and it's one thing to look for especially in buying used lenses (and certain types of shutters). Usually you can See the oil on the blades if you look carefully. It will typically show up as a wet looking discoloration on the edges where the rest of the blades appear dry. In many cases, it's easier and cheaper to replace the lens when it happens than to have it serviced. To do a proper cleaning job, the aperture blades must be removed from the lens and cleaned individually. My price for doing it for someone else starts at $75 and goes up depending on the lens. That's assuming I can even get it apart.
Leaving a lens in a hot closed up car exposed can also cause it.
With respect to your kit lens, I'm sure the Sigma is a quantum leap better in terms of sharpness. You nailed one possible cause for the halo effect, overexposure, which is what prompted my response.
