12-04-2010, 02:57 PM   #1
Problem with Sigma Lens
I have been using a Sigma EX 70-200 2.8 for several years to shoot wrestling. Today, I kept getting the F-- in the exposure window. I don't know why. It didn't happen on every shot, but it happened way too much! I took the lens off of my K20D and tried it on my K100 body and had the same problem. Does any one have a suggestion as to what the problem could be--- or where I could get some quick service.
12-04-2010, 03:05 PM   #2
enoeske's Avatar
turn the aperture ring back to the A position
12-04-2010, 03:13 PM   #3
Thanks for your response.
I tried that. I still get the F-- . Any more suggestions! I am getting desperate!
12-04-2010, 03:14 PM   #4
enoeske's Avatar
clean the contacts on the lens with a soft pencil eraser or damp cloth
12-04-2010, 03:27 PM   #5
Oh no,
That didn't work! Now, when I turn on the camera.... in any mode I get a blinking F--. It will not even let me change the F-stop using the rear control.
12-04-2010, 04:10 PM   #6
jimr-pdx's Avatar
I'll be watching this thread for hints, as my Sigma 14mm f/3.5 is experiencing the same problem. I took a bunch of shots in 'A' / auto modes, they were all shot wide open and came out very soft. Works great in full-manual mode.
12-04-2010, 04:49 PM   #7
Jodokast96's Avatar
Is there any play in the lens when mounted, prohibiting the contacts from touching? I get this at times with my extension tubes with long, heavy lenses.
12-04-2010, 06:18 PM   #8
Hoping for some more insight.
There is no play in the lens keeping if from making contact. It won't even work in Full Manual Mode Now....
12-04-2010, 06:49 PM   #9
Lowell Goudge's Avatar
Do you have an ohm meter? Check the resistance to the A pin from the lens mount It should be less than about 10 ohms. It sounds like you have lost contactto this pin. Also confirm that other lenses still work
12-04-2010, 07:36 PM   #10
Where is the A pin?
I do have access to an ohm meter.
12-04-2010, 07:42 PM   #11
This particluar lens
Is not working on my *istDL, K100, or my K20D! I was actually thinking that it might be a camera issue...so, I tried all three bodies.
12-04-2010, 07:50 PM   #12
twilhelm's Avatar
I have to believe this is probably a contact problem with the pins.
I have had a similar problem with my Sigma 28-105 f4 for the past couple of years, since it was new. Normally I just put pressure on the lens as though I am trying to wiggle the mount and it corrects itself, occasionally I have to remove and remount the lens.
Though I've never had it happen while I was shooting.
I do like the lens so I too will be watching for some kind of solution.
12-06-2010, 07:45 PM   #13
jimr-pdx's Avatar
Speaking for my 15mm, I fear it's the little circuit board. My old ohm meter shows little movement so it isn't grounded, and I opened and cleaned every metal contact
(and spent 1/2 hour reinstalling the ball bearing that makes the f-stops click ). Not much else to try in the obvious dep't.. and I fear Sigma wants $100 just to undo
three screws much less solve anything. Bummer. Oh yeah, I wiggled aperture ring & mount; no change, always F--.
Any other suggestions?
01-07-2011, 08:50 AM   #14
Hello
I have had that with a sigma 70-300 DG.
The unique solution was to have it repaired by Sigma and now two years later still no problem.
Best regards,
k-mount, lens, pentax lens, sigma, slr lens
Would a SIGMA non-DG lens be a problem in a K20D? peru Pentax SLR Lens Discussion 3 09-12-2010 05:53 PM
Focus problem with Sigma Zoom 28-80mm 1:3.5-5.6 Aspherical AF lens GrahamS Pentax SLR Lens Discussion 4 12-02-2009 05:45 PM
Sigma 10-20 problem ozlizard Pentax SLR Lens Discussion 4 07-25-2009 10:39 PM
Problem with sigma Zoom Keith Pentax SLR Lens Discussion 6 09-24-2007 05:32 AM
Sigma/Pentax lens problem fevbusch Pentax DSLR Discussion 15 02-10-2007 02:04 PM
All times are GMT -7. The time now is 10:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
