Quote: Now, eventually it would be great to have all of the DA Limiteds: 15, 21, 35, 40 and 70. But, given my current lens collection in my signature below, where you you start if you were me?
I get the sense that for you, as for many, debating the relative merits of lenses has become an end in itself. It would be great to have a lot of things, but why do you actually need ANY of these lenses? What focal length do your zooms gravitate to?
Until you can say what lacks in your current set-up in terms of the photography you actually do, any money you spend will be fun short-term but ultimately pointless. I have spent hundreds of dollars (Singapore dollars and pounds sterling in my case) buying lenses I don't really need. It has been very instructive. I have learned about the technical performance of lenses. I can read reviews with a knowing expression on my face. Has this improved my photographs? Not much. The money would have been spent more productively on air tickets.
Benefit from my experience.
So. What are you trying to achieve? In my case I finally decided what the key issue is: lugging heavy zooms around all day in tropical heat is an unacceptable experience. That's why I have gone the DA Limited route. I dislike front-heavy cameras too. But I now also apply a rule: I don't buy a lens without selling a lens.
You have a perfectly serviceable set-up. What's actually wrong with it? When did you last print a photograph larger than A4? If so, what was wrong with it?
Hi fi nuts spend thousands of dollars chasing differentiation inaudible to 99% to the population, and probably also to themselves in a blind test. Do you realise how much some people spend on speaker cables, for god's sake? Is there a possibility that you, similarly, are enjoying the debate about lenses more than the real photographic benefits they produce?
Just asking.
End of late-night rant. Blame jetlag.
Tim
