Originally posted by Twarp @Marc, I don't mind you questioning my train of thought considering trying to find a solution to a (sudden, it used to be good, that's the weird part) blurry focus problem.
As I've said before, if the placebo effect is string enough for people to perceive a lessening of symptoms and indeed even increase the rate of spontaneous cures (which it is) after being given a sugar pill, then it's certainly strong enough to make one believe one's lens has developed a problem after some random event causes them to notice things that have been true since day one.
I'm not saying that there is no chance your lens has somehow spontaneously developed a problem - a problem for which there is no known physical phenomenon that possibly produce the alleged results. But I am saying that the act that it *seems* the problem just started doesn't surprise me; that's not even the least bit uncommon. The normal operations of AF are such that there is always the chance that the camera will choose to focus somewhere other than you expect. At first, you write off such occurences as random, but at some point, you become convinced there is a problem, and then you start noticing it everywhere. It's a story that has been repeated here and elsewhere hundreds of times. So I personlly would put zero stock in the perception that the something has changed recently; that's an almost completely unreliable perception and impossible to test for since you don't have a time machine to allow you to perform controlled comparisons.
So, step is to try to regain objectivity in your testing and focus on what can actually be tested: performance *now*.
Quote: At the moment I select the central focus point I think I may rule out that the camera randomly chooses another of the 10 remaining focus points. The K-x has no red dots to represent the focus points but from other posts I understand that they are only indicators and in several documented cases do not coincide with actual focus points (like a misplaced overlay).
No, not like a misplaced overlay. It's just a simple matter of size - the red dots are much smaller than the actual focus sensors. The camera can and will often focus on an object that is not directly under the red dot.
Quote: I assume that the selected central focus point in the viewfinder coincides with the actual center of the screen which then may be used to 'aim'. If the actual aimpoint would have been off-center, one could adjust accordingly. Just like you would do with misaligned sights on a gun. Please let me know whether I make a mistake here or leave something critical out of the calculation.
Well, you are undoubtedly correct that the actual center of the viewfinder is somewhere within range of the central focus sensor. However, you still uave not ascertained the complete range of that sensor. That's a useful experiment as well, and the same setup should prove useful - just keep trying to focus on an object while moving the camera to put it increasingly off-center.
Quote: I actually shot a brick wall from ca. 1m distance, the lens parallel to the surface. In this case, no matter what focus point the camera would have chosen, without correction no total sharpness could be achieved with AF. A correction of +130um gives best=sharpest results with this lens/camera combination. This is repeatable in different circumstances (daylight/artificial light, different targets and distances, etc.). The pictures of mgvh perfectly show what I found as well, coincidentally with the same correction.
Assuming you really were perfectly parallel (how did you measure this?), then yes, that's a pretty good test result. I'd just observe that there is no known physical phenonemon that would cause the *lens* to have any involvement in that if you test was really as exhaustive as you say - and in particular, if you tried testing with the initial focus point at infinity and also at minimum. If the focus is consistently off, then there is one and only one very simple physical explanation: the focus sensor within the camera is not at the same distance from the lens as the imaging sensor. People have theorized about possible ways the lens could be involved - suppositions about the gearing ratio of the focus screw being off, or residual CA that causes the focus point to change as you stop down. If either of those were the case, though, your focus discrepancy would not be consistent at all. If it were something in the gearing, you'd get different results dependning on where the initial focus point was. And if it were residual CA, you'd only see an issue as you stopped down (and it wold become difficult to see since DOF would mask it).
