Originally posted by SamD Ordered an adapter today. Can't wait to get it and try my new lens.
Thanks for the help.
Sam
My adapter never leaves the body!
There are some tricks to using M42 with the K-x, and here are the basic tips:
1) First and foremost, before you do anything, you have to get into your custom settings and select
Use Aperture Ring--Permitted. Otherwise, you'll get a flashing
F--. You'll still get the
F--, because the lens can't communicate aperture, but it shouldn' flash. And aperture info isn't saved in your EXIF data, which can be an annoyance at times. The
Use Aperture Ring--Permitted will stay like that by default each time you power up the camera, and that's okay.
2) When you first power up the lens, since it's a manual lens, you'll be asked to select the focal length. This is for shake reduction, and obviously, you select 28.
3) You can shoot in Av or M mode only. However, on some lenses, like most of my Taks, Av mode underexposes. You can either set an Ev compensation to use for all your shots, or use M mode, which is what I do. (But your lens might meter perfectly.)
4) In M mode (I use center weighted metering), I place the metering segment on the part of the scene I want to best expose for, hit the Ev+- button to lock in the shutter speed based on the aperture I selected (make sure your lens is set to M), and then recompose my frame. On the K-x, you don't have to use the Green button to lock in the shutter speed. The Ev+- defaults to this function in M mode.
5) When shooting in M and I want to add some compensation, like opening up a stop from the metered reading but still want to keep my selected aperture, I do this:
I want to shoot at F8, but I set my ring to 11, get my reading, then open to 8.
Yes, you won't be shooting any NASCAR with this method, but it works in many situations.
6) You will still get focus confirmation (beep and hexagon), but if you're really stopped down (to like F16), depending on the lens, you might not. There's nothing wrong with the lens or camera--I guess it's just the nature of the beast that the AF system can't handle this all that well. Also doesn't matter if you have the camera body set to manual or autofocus.
Have fun!!!
