12-10-2010, 04:55 PM   #1
Arpe's Avatar
I've got a tight ring, fixable?
I have acquired a FA 80-320. The zoom ring is sort of sticky, like it's too tight. Is there some way of making it smooth again (without spraying oil down there )? It's really only bad from 200-320.
Thanks.
12-11-2010, 12:35 AM   #2
nulla's Avatar
You have really left yourself open to all sorts of replies.
12-11-2010, 12:36 AM   #3
Frogfish's Avatar
QuoteOriginally posted by nulla Quote
My first thought too !
12-11-2010, 07:58 AM   #4
Lowell Goudge's Avatar
QuoteOriginally posted by Arpe Quote
Thanks.
I'll pass on the jokes, although it did make me pause for a moment
One thing I have noticed on consumer FA lenses is that pentax optical design has the lens go through an inflection point, where the overall length of the lens changes from being long as you are zoomed out to short at some middle point and getting long again when zoomed all the way in. The zoom stiffness changes between these two extremes, making the feel somewhat inconsistant. Don;t know if this applies on medimum to long tele zooms but certainly does on wide to medium tele.
BTW, is this a power zoom lens?
12-11-2010, 11:28 AM   #5
Just1MoreDave's Avatar
Zooms have one or more concentric lens barrels. One construction method to control the movement between barrels is a groove in the outer barrel, and a nylon roller bearing within the groove. Usually a pair of grooves and bearings. The change in direction means a V shaped groove. If one nylon bearing cracks or breaks, it can cause that kind of sticking feeling.
I have a pretty low rate of success fixing this type of problem. Some of the time, you can see what's not working, but not make it any better - lack of correct part, etc. Sometimes there are four concentric barrels and the problem one is buried. I'd wait for it to get worse.
12-12-2010, 04:36 PM   #6
Arpe's Avatar
Yeah I know, nice to keep people amused though!
No not power zoom. Yes there's a definite pause around 200mm.
QuoteOriginally posted by Just1MoreDave Quote
And then what when it gets worse, dump it?
k-mount, pentax lens, slr lens
Is my Pentax-A 135mm f2.8 Fixable? man_frotto Pentax SLR Lens Discussion 8 11-10-2020 03:03 PM
Fixable problem, or ignore it? foxglove Pentax DSLR Discussion 10 12-30-2009 09:27 AM
Can a tight focus ring be fixed? Bobr99 Pentax SLR Lens Discussion 8 09-21-2009 07:17 AM
Busted A 50mm 2.0, fixable? travfar Pentax SLR Lens Discussion 1 08-05-2009 08:54 AM
fixable sensor problem? slaw0710 Pentax DSLR Discussion 1 07-18-2009 03:09 PM
All times are GMT -7. The time now is 06:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
