12-12-2010, 10:39 AM   #16
paperbag846's Avatar
QuoteOriginally posted by greymda Quote
a very good UV filters test:
UV filters test - Introduction - Lenstip.com
__________________
Read this.
12-12-2010, 10:54 AM   #17
Laurentiu Cristofor's Avatar
A good test, but its ranking is not relevant to digital use. Lenstip evaluates and ranks those filters for their original purpose of cutting out UV. But digital sensors aren't sensitive to UV, so you only care about transmission in the visible light range. If you look at that, then the top filter in the lenstip results, Hoya HMC UV(0) is actually looking a bit worse than the B+W UV-Haze MRC, because it has a more irregular transmission curve for the visible spectrum, while the B+W has a smoother curve.
12-12-2010, 11:44 AM   #18
twokatmew's Avatar
Check out Marumi Super DHC multicoated filters. I have both 49mm UV and CPL filters. I got mine on Ebay from oeccamera. Here's the link:
Marumi 49mm Super DHG UV
12-12-2010, 05:50 PM   #19
pschlute's Avatar
I would not bother with a filter for normal use of the DA 40mm, but if you insist you can get a 30.5mm filter and screw it on the inside of the hood.
40mm, 49mm, filter, filters, glass, k-mount, pentax lens, piece, slr lens, uv, uv filter
which 40mm? pentax da 40 or Voigtlander Ultron 40mm f/2.0 SL-II dexmus Pentax SLR Lens Discussion 12 10-30-2009 07:26 PM
Filter, New Cap for DA 40mm prime lens Earlybird Troubleshooting and Beginner Help 4 08-01-2009 12:35 PM
All times are GMT -7. The time now is 08:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
