12-14-2010, 02:02 PM   #1
soppy's Avatar
Reversing a DA 40mm Ltd.
Is this possible? What kind of magnification could I expect?
12-14-2010, 02:58 PM   #2
blackcloudbrew's Avatar
I think, that it's not possible due to the lens hitting the pop up flash mount. I believe I tried this with my DA 40 on my K10/k20 with a reversing ring. Honestly, the best lenses for this that I've tried is an FA 50.
12-14-2010, 08:06 PM   #3
RioRico's Avatar
What you get from reversal is a flat-field, close-work lens. Close, like 45.46mm, which is the lens register (flange focal distance). You'll get that same working distance by reversing ANY Pentax-compatible lens of any focal length.
Magnification results from extension, not reversal. A reversed lens with a deeply inset objective will show some magnification, because that inset acts as extension. Otherwise you need to add extension such as macro tubes behind the mount-reversal adapter.
Sorry, I don't know how to calculate the magnification you get with simple reversal. With enough extension, you'll clear the flash snood. Macro tubes are cheap. Give it a whirl.
12-14-2010, 08:41 PM   #4
The DA does not have an aperture ring, right? That might be an issue, you'd have to wire the aperture lever open or you're stuck at f22.
12-15-2010, 12:01 AM   #5
axl
QuoteOriginally posted by blackcloudbrew Quote
If FA50 doesn't hit flashmount how could DA40 do so?!?
I believe it's possible but yoy will have to tape the aperture lever in open position as suggested. Otherwise you have f22 and very dark VF.
da 40mm, k-mount, pentax lens, slr lens
Reversing lenses Gary G Pentax SLR Lens Discussion 25 11-13-2010 05:07 AM
Macro - Reversing Lenses jaieger Photographic Technique 8 09-06-2010 03:40 PM
Reversing ring for P67 alfa Pentax Medium Format 3 04-02-2010 06:06 PM
Reversing ring? axl Photographic Technique 10 05-30-2008 08:35 PM
Reversing a file GRIZZLY GULCH Digital Processing, Software, and Printing 2 02-16-2008 08:48 PM
All times are GMT -7. The time now is 12:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
