Originally posted by axl I have to say that my K10+31ltd are very erratic combo. And at f1.8 past 2-3meters the lens is not at it's best. Combine those two and there you go...
Axl, that may not be a great combo (K10 + 31 Ltd) but I am starting to believe that it isn't that great either with the K7/31Ltd combo.
One thing I will also do is to compare this with a K20D /31Ltd combo over the weekend.
Annoyingly, it seems to get worse when the subject to camera distance increases. Worse, in the sense that I get less keepers (subjects in focus) whether it is with AF or manual focusing, even at F5.6 .. F8.
And then, there is the obvious softness at F1.8 (with the K7); not much better than with your K10D/31 Ltd combo.
Seemingly, the lens/K7 camera performs better using a close distance-to-subject with flash, indoors!
I took some shots at a party this past weekend and the results were rather satisfying.
Which now means that I am pretty much mixed up as far as fine adjusting the AF.
More or that after the weekend.
Cheers.
JP
P.S.: I wonder what the says are with the K5 and the FA 31 Ltd ??
