Don't sand that lens! There is a simpler, non-destructive way to short the PKA-mount contact pins with an M42 lens. Assuming the lens has a wide enough base, just cut a strip of metallic tape and stick it onto the lens base in the appropriate position. A duct-tape-size roll of metal heating-duct tape only costs $US4-5 and provides enough tape for hundreds of lenses.
Dealing with the auto-aperture pin on an auto-only M42 lens is another problem. I have read that an M42-PK adapter ring with an inside flange to depress that pin is available... for something over US$100. Ouch. With my first such lenses, I superglued the pin down -- but that seems to be irreversible, and I wouldn't do that to any lens I might hope to sell in the future, not to use on an M42-auto body. I have modified a few lenses but I'm not comfortable with disassembling a lens to jigger the auto pin. So my other solution is: don't buy such a lens. Stick with M42 lenses that either have aperture presets, or M/A switches.
About the CZJ Tessar 50/2.8: I have two very different copies. Neither has a serious exposure problem with Av mode on my K20D. One copy is a big black M42 with an M/A switch and 5 iris blades. The other is a small aluminium Exakta-mount with preset aperture and 12 iris blades -- BOKEH MONSTER!! I mount the latter using a simple modified adapter I describe in another thread here. I don't know why some CZJ Tessars cause exposure problems on some cameras but not others. I can't just blame karma...
