12-21-2010, 12:59 PM   #31
Cambo's Avatar
No, I've only tried it briefly...
QuoteOriginally posted by GeneV Quote
So, if you are not talking about measurebating (on which the DA17-70 does quite well), then what is the basis for saying that the IQ of the 17-70 is not worthy of being a comparison for zooms in the range we are talking about? Have you actually used it?
I've taken a few thousand shots with it, and found it up to the task. I'll probably have an 18-135 as well, someday, as it appears to be a nice lens, but I see that lens as serving a different purpose. It seems like we've both participated in other threads where the consensus was that one should not expect IQ from a 7x zoom that you find in a 2x or 4x.
but there must be some reason that it's a DA rather than a DA* series lens. And having been used to the stunning optics of the FA* 28-70 f=2.8 and the 85 f1.4, I was wondering if I'd be satisfied with the performance of the 17-70 at f=4 over the 16-50 f 2.8. I know I'll like the weight advantage.
Similarly, is there a really big difference between the 50-135 and the 60-250? They're BOTH designated * lenses, so aside from the one stop of speed, is there a lot of difference in real world performance between these two?
Thanks,
Cameron
12-21-2010, 02:35 PM   #32
GeneV's Avatar
QuoteOriginally posted by Cambo Quote
Thanks,
Cameron
The DA* is weatherproof and one stop faster. That is definitely worth something.
My comments pertained to the 17-70 as compared to the 18-135, based upon my experience with the 17-70 and threads already posted with examples and comparisons from the 18-135. I've never owned the DA* 16-50 and would not venture to comment on whether someone else would be satisfied with the 17-70 after owning the DA*.
There are more zooms, and more zooms of quality, in the approximate range of the DA*16-50 than other DA* lenses. I don't think Pentax makes another zoom with anything like the performance of the other DA* zooms. For example, in published tests, the DA*60-250 is much more clearly superior to the well-regarded 55-300 or the less regarded 50-200 than the 16-50 is to the 17-70 or 16-45. In photos posted here, the 18-135 was clearly not up to the performance of the DA*50-135 at ranges they share.
12-22-2010, 04:54 AM   #33
You'd be satisfied, it's IQ is as good as the 16-50's in the comparable focal lengths and apertures. I was using DA 17-70 for 20 months, now I have DA* 16-50 and its IQ isn't noticeably better (in fact it's worse at the wide end, performance at f/2.8 also not very good).
Get the DA* 16-50 only if you need full weather resistance and f/2.8, otherwise DA 17-70 is a good choice for much lower price (here the price is half of the 16-50's, not sure how it is over there.)
12-22-2010, 09:02 AM   #34
QuoteOriginally posted by twitch Quote
I'd say get the f2.8 double. You can always add a da*200 or 300 later
QuoteOriginally posted by panoguy Quote
Or, if you don't need the longer end, split the difference! I've been quite happy with the Tamron 17-50 and DA*50-135.
I agree with both these guys...
12-22-2010, 09:08 AM   #35
JHD
QuoteOriginally posted by Ubuntu_user Quote
Optically the 50-135 is a nice lens, but it is a liability with a short warranty. The Tamron 70-200 f2.8 is almost $200 cheaper here in Canada with a much longer warranty.
12-22-2010, 10:00 AM   #36
Cambo's Avatar
WR...
I didn't realize the 17-70 wasn't weather sealed. That lets it out of the running then.
And the 55-300 that I tried was TERRIBLE - VERY VERY noisy screw drive focus, worst I've ever heard, plastic lens mount, and when I added the photos in iPhoto, the lens wasn't recognized (all the others I tried were).
So it's a battle now between the 50-135 and the 60-250 in terms of IQ. Any more thoughts?
Thanks,
Cameron
12-22-2010, 10:07 AM   #37
dgaies's Avatar
Thanks,
Cameron
The original 55-300 comes in a metal mount; you must have tried the DA L version that comes with the K-x/K-r. Regardless, the AF is a bit noisy so if it bothered you the fact that it comes in a metal mount is moot anyway.
Optically, the 50-135 and 60-250 are both excellent, I don't think either one would let you down optically. The 50-135 is nice because it's smaller, doesn't expand (IF) and is a stop faster. The 60-250, OTOH, has an excellent range and is very sharp from wide open on up. In terms of focus speed, the AF of the 60-250 is a bit faster than the 50-135. Neither are blazing fast though, so if super fast AF is critical then you might need to try one out and determine if it's fast enough for you.
12-22-2010, 04:18 PM   #38
Ex Finn.'s Avatar
The 16-50 weatherproofing is a big deal in my book. Little moisture does not send it home crying. (And yes, the 540 still works.)
12-22-2010, 05:49 PM   #39
GeneV's Avatar
Weather sealing is normally not a big deal to me. I don't have a single WR lens out of a couple of dozen that I own. I very seldom shoot in conditions where that is an issue. Even when I've shot in the rain, all the non-WR equipment came through it just fine. However, if I do buy a WR lens, it is likely to be the 18-135. I, personally, would sacrifice the ultimate degree of IQ for a WR lens that I am unlikely to need to change in inclement conditions.
12-22-2010, 06:41 PM   #40
Ex Finn.'s Avatar
It is a compromise between IQ and weather proofing IMO. There is no point in pixel peeping something shot in a blizzard. What matters in that situation is that the lens/rest of the gear survives, to be used the next time. So far Pentax has done well in that department.
My choice would be the 16-50 and 60-250 combination.
12-22-2010, 06:56 PM   #41
kcmadr's Avatar
QuoteOriginally posted by Ex Finn. Quote
YES!!!
I would love to have this combination. If only it weren't for the 16-50's history and the fact that the 16-45 does a pretty darned good job. The 16-50 is also a monster compared to the 16-45. I know, the 16-45 doesn't have weather sealing, but my ideal setup will probably end up being 16-50 + 60-250.
JMTC
12-22-2010, 07:43 PM   #42
Ex Finn.'s Avatar
The 60-250 is no light weight either. Images from it are very good for a zoom.
12-22-2010, 08:17 PM   #43
Cambo's Avatar
Tried the 60-250
QuoteOriginally posted by dgaies Quote
very nice lens, quiet, extremely CHEAP lenshood for a lens that costs almost $2,000.00, and I didn't realize it was an external zoom, which I actually hate. So it looks like 16-50 and the 50-135, later on the 200 or 300.
Thanks, everyone. And a merry Christmas or whatever you celebrate this time of year.
Cheers,
Cameron
12-22-2010, 08:22 PM   #44
Ex Finn.'s Avatar
There is that little caveat, not fan of it but can live with it
And merry Christmas.
12-22-2010, 08:34 PM   #45
dgaies's Avatar
Keep in mind the 60-250 and 50-135 share the exact same hood.
Didn't know the 60-250 was $2k up in Canada. If you change your mind and end up considering the 60-250, you may want to consider importing one from the US where it's about 1200. Even with potential taxes/shipping it might be worth considering.
da*, k-mount, pentax lens, slr lens
DA 18-250/ 18-135 compare shots Fl_Gulfer Pentax SLR Lens Discussion 10 12-10-2010 08:49 PM
DA* 50-135 or 60-250? photoholic Pentax SLR Lens Discussion 6 07-28-2010 01:53 PM
da*50-135 vs da*60-250. Need help choosing bfo Pentax SLR Lens Discussion 44 03-06-2010 04:53 PM
Has anyone compared DA*50-135 vs DA*60-250? HermanLee Pentax SLR Lens Discussion 3 05-26-2009 11:50 PM
TAKUMAR 135 vs PENTAX 18-250 charliezap Pentax SLR Lens Discussion 7 04-04-2009 07:35 AM
All times are GMT -7. The time now is 11:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
