Originally posted by snostorm All of these are "one touch" zooms, which means that you slide the focus ring to zoom and the lens does not change length.
Scott
Thanks for your input Scott. You've made some pretty good suggestions, and I've been looking at most of those as candidates. Specifically the Pentax 70-210 f4. The Tamron 70-210 f3.5, although it is a lens I would like to pick up simply for it's IQ, will not work for my purposes as it extends when zoomed. That particular lens, and indeed most tamron SP one touch zooms, were designed as extension type zoom lenses.
The Komine / Vivitar, is one that I would love to nab, but as you mentioned, they are very rare and usually quite expensive.
I hadn't considered the Tamron SP 80-200 f2.8. I had a chance to pick one up a while back but didn't because the seller was a little sketchy on getting me pictures of the "light fungus" that infected the front element. Would have been a great bargain but I'm not about to inherit another lens with fungus that I do not have the time to learn how to fix. So I'm curious, does the Tamron 80-200 f2.8 extend when zoomed? Doesn't look like it from the pictures.
Another question you might be able to help with, are any of the suggested lenses, specifically the Pentax 70-210 f4, the tamron 80-200 f2.8 and the lens sugested in the previous reply by Just1MoreDave the Pentax F100-300, Parfocal lenses?
To get a better idea of the why behind all this check out my comment on another post regarding revers macro setups
Here
Just so you know, my wet dream would be a lens that is both internal zoom and internal focus. Doesn't necessarily have to be a slide zoom. Not that it matters that much, but zoom creep sucks if you have everything just the way you want it and the thing starts sliding down on you. It would also be helpful if the front element of the lens in question is a manageable size so i can easily revers a fast wide prime in front of it.
Again, thanks for your help and your great suggestions.
