12-23-2010, 05:39 AM   #1
scorpioh's Avatar
Need a check with owners of the FA*24mm f2.0
I had just acquired a pre-owned copy of this lens. Upon closer inspection of the lens through bright light, I'd realise that there is a very faint concentric circle within one of the lens group. Yes, it looks like the boundary of an element that had been glued on to another. There also appear to be very minute bubbles/spots appearing evenly over that element's surface if I am right. It isn't really all obvious but faint enough such that it can only be observed through a bright light source at certain angles (within the shadows). It's rather hard to be photographed and I hope my description is good enough here.
To clarify, the observations were made by looking from the rear at wide open aperture (ok, obviously).
I am wondering this this is a sign of element separation or just normal for this lens. I have checked with some of my other lenses and do not quite observe this. Can some kind souls check theirs or advise accordingly? Thanks!
P.S. I really love this lens.
12-23-2010, 05:51 AM   #2
axl
I'm on my way to work. Don't have the lens on me and won't be home anytime soon with busy tomorrow. I'll try to check over Xmas and will let u know. Although when I was examining my copy before purchase I haven't noticed anything like that. But will double check and let you know.
Regards
12-23-2010, 05:54 AM   #3
scorpioh's Avatar
QuoteOriginally posted by axl Quote
Regards
Hey, thanks axl! I had you in my mind while posting this thread. Ha.
12-23-2010, 06:03 AM   #4
scorpioh's Avatar
Ok, I am trying to find out more on the net and came to this:
The Mamiya 50mm f4 for M6, A shocking observation! - Photo.net Medium Format Forum
To quote:
"True separation of lens elements can usually be seen by transmission (i.e. looking through the lens) as well as reflection, and appears as slightly grey, less clear patches of roughly circular shape." (Pete Andrews)
In my case, the bubbles/spots are uniformly spread across and the "concentric" circle/lens element outline/boundary is perfectly circular with no "broken lines". Maybe its a poorer glue job than separation?
12-23-2010, 06:45 AM - 1 Like   #5
My FA*24 shows no similar problem if that helps. But it is also quite worn and Pentax service says they miss the spare parts to replace weakened mechanic components.
I really wish for a DA* replacement of this lens. I'd gladly sacrifice 1000euros for one.
12-23-2010, 06:45 AM - 2 Likes   #6
blende8's Avatar
QuoteOriginally posted by scorpioh Quote
Yes, this is a typical problem with this lens. The aspherical lens element is a piece of plastic glued on a glas element. There have been reports of separation and yellowing of this piece.
That's the reason why this "star" lens is not as highly regarded as the other star lenses.
12-23-2010, 07:05 AM   #7
scorpioh's Avatar
QuoteOriginally posted by blende8 Quote
I see... Thanks! Plastic?! No wonder... But I think it is nothing to worry about at this stage since it's really very mild, perhaps like this ever since it left the factory and hopefully doesn't worsen.
12-23-2010, 07:05 AM   #8
scorpioh's Avatar
QuoteOriginally posted by elho_cid Quote
Ironically my copy is pretty minty. Guess I'll live with it. Thanks for your help! Merry X'mas!
12-24-2010, 01:24 AM   #9
axl
Well, I managed to check mine. No such problems. On a side note, my copy is in great shape so I hope it'll last. But yes, the DA*24 would be nice!
check, element, k-mount, lens, light, pentax lens, slr lens
Input from DA* 200mm Owners: Owners Regrets over 300mm ? BBear Pentax SLR Lens Discussion 57 08-12-2013 12:22 PM
DA* 50-135mm owners: could you check something for me? aerodave Pentax SLR Lens Discussion 21 05-25-2010 09:21 PM
Price to have Pentax check a lens? (FA* 24mm) arpaagent Pentax SLR Lens Discussion 19 03-14-2010 09:30 AM
Suggestion for Sigma 24-70 owners (or potential owners) joeyc Pentax SLR Lens Discussion 4 08-07-2009 03:12 AM
Calling Tamron 10-24mm owners ManixZero Pentax SLR Lens Discussion 10 07-21-2009 12:48 PM
All times are GMT -7. The time now is 12:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
