12-23-2010, 05:08 PM   #1
What is back focus?
New term to me for my 2010 photo vocabulary- Back Focus
What is back focus?
The reason I ask, is that I was contemplating getting the DA* 55MM SDM F1.4
(for my K-7)
In the reviews, they say this lens has back focus issues and that the SDM is slow compared to the drive AF on the FA 50mm.
I have seen SDM on Canon and Nikon (don't kill me, the local pros I work with let me borrow their cameras) It is so quiet! It will help when shooting pets and also people in a quiet venue like a classy restaurant.
Is slow SDM focus really a problem for indoor settings?
But the back focus everyone commented on might determine if the $600 is worth it.
I hope everyone has a wonderful Christmas!
12-23-2010, 05:14 PM - 1 Like   #2
v5planet's Avatar
I can't answer your SDM questions as I don't own the lens, but back focus is when the camera focuses the lens such that the focus is locked on something behind its intended target. The result is what you thought you were focusing on will be slightly out of focus, whereas something behind it will be much crisper. There are numerous causes of backfocus, which can be caused by the lens or the camera itself, and sometimes may be exacerbated by bad lighting conditions (at least in my experience).
Fortunately your K-7 has settings that you can use to compensate for back (or front) focus. In severe cases the range of possible adjustments might not be able to compensate for the problem.
12-23-2010, 07:52 PM   #3
DA*55 is not a slow focus lens at all... if you do not shoot very fast moving objects, such as sports, sdm is fast enough, even for infoor settings.
I didn't hear much about DA*55 back focus problem, but if it does back focuses, it's really annoying. Fortunately the k-7 has focus adjustment function, so if the back-focus problem is not very severe, you can alway adjust it yourself, especially considering that DA* 55 is not a zoom.
12-24-2010, 02:49 AM   #4
-Mous-'s Avatar
I've used my DA* 55/1.4 on both the K10D and K-7.
On the K10D there used to be a constant back focus in almost every shot. I had to hack the firmware to adjust for this, bacause the K10D doesn't normally support this.
On the K-7 the focus is much better. It hardly ever back focusses, and only in very bad light conditions wide open. This does make it hard to adjust for though, despite the K-7 supporting this, because it's not constant. I have setup the adjustment level and only turn on the adjustment when in a situation experiencing back focus. This only happens sporadically though.
The focussing speed is the slowest of all my lenses (see my signature). The DA 35/2.4 is a lot faster, but the focussing speed of the DA* 55/1.4 is still very acceptable. It's still my favorite lens.
focus, k-mount, pentax lens, sdm, slr lens
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
Trying to understand front focus/back focus thing 41ants Troubleshooting and Beginner Help 16 08-31-2010 08:42 AM
Front/back focus or focus shift? fulcrumx29 Pentax SLR Lens Discussion 0 08-17-2009 04:56 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
How to check Back Focus/Front Focus grishazzz Troubleshooting and Beginner Help 14 03-18-2009 11:35 AM
All times are GMT -7. The time now is 06:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
