Originally posted by magkelly
So what you all are saying basically in layman's terms is that you're not actually getting more distance you're just getting a tighter cropped shot?
BY GEORGE, S/HE'S GOT IT!! (*) Yes, that is exactly right.
For instance, back in the day, I had a Spiratone 400 long lens in T-mount. I could use it on one adapter for a full-frame Nikon F (landscape aspect), and another adapter for a half-frame Olympus Pen-FT (portrait aspect). From the same location, shooting the same lens and subject, I could snap a shot with each. The half-frame image would be EXACTLY the same as if I had cropped 1/4 from each side of the full-frame image. NOTE: the APS-C sensor in you dSLR is just about the same size as half-frame 35mm.
So comparing a lens on full-frame and APS-C, think of the APS-C sensor as performing an in-camera crop.
Where the math get tricky is that field-of-view is computed using the DIAGONAL of a frame, while sensor sizes define the AREA of a frame. The diagonal of FF is about 44mm; the diagonal of APS-C is about 29mm; so FF is about 1.5x the APS-C dimension. But an FF frame has TWICE the area of an APS-C frame. Blame Pythagoras.
(* Please excuse me for not recalling your gender affiliation.)
