01-31-2011, 09:22 PM   #16
did you replace it with a steel mount or the original plastic mount? Can you post the part #?
02-01-2011, 01:32 PM   #17
Original plastic mount.
48167.0M107 Bayonet Ring Assy. $6.72
02-05-2011, 08:51 AM   #18
thank you so much. I wonder if we can order the steel mount and put it on our DA L lens. Do you possibly have that too?
03-11-2011, 04:41 AM   #19
Hiya
Can I ask how long you had the lens before it needed repairing? Just bought one with the same mount and whilst I may not have that problem it's good to be forewarned.
Thanks
B
03-11-2011, 06:02 AM   #20
Hmmmm.... I was thinking of taking the plunge on one of these, but I definitely don't want the plastic mount version. Is the steel mount version typically more expensive?
03-11-2011, 06:41 AM   #21
sterretje's Avatar
Why not? For all I know (as he/she did not come back on the question I asked) the OP used camera and lens as a hammer to nail some 10" nails in a solid oak barn door .
And yes, the metal mount is more expensive, but also comes with lens hood (I've heard that the original Pentax is about $50), quick shift, and distance scale on the focus ring.
03-11-2011, 07:15 AM   #22
On the other hand, since the replacement mount is under $7, if it ever did wear out, it would be no biggie to replace.
03-11-2011, 09:59 AM   #23
actually the mount is just same..
just replace the mount with any metal mount from other DA series if you have..or with FA/A lens..but noted that DA lens have extra contact for exif information..
it is very easy to disassemble..
i just curious, how the mount can be broken? did you hit the lens on something while mounting it on camera? or did you drop the lens? even it is plastic made, it is quite hard to be broken except it already cracked while in production..
03-11-2011, 11:46 PM   #24
I broke the plastic mount while on a cruise excursion in Jamaica. The truth is, I had the lens mounted on the camera body in my Lowepro slingshot while I was on a horseback ride. But then I fell and landed on my back/side. Ouch! I didn't even know the plastic mount broke until I got back on the cruise. Even though the mount is plastic, I don't think it can break easily unless you suffer the same fate as I. After the replacement, the lens is now good as new.
03-12-2011, 05:59 AM   #25
sterretje's Avatar
Indeed ouch. And shit happens. Hope you're further OK and that it did not spoil the trip.
And to moo1971 and GibbyTheMole
Does not sound like there is a need to doubt the quality of the plastic mount.
03-12-2011, 06:42 AM   #26
Yeah, after doing some research it looks like the plastic mount really isn't anything to worry about. I'll probably wind up picking one of these up. - Bob :-)
03-12-2011, 11:03 AM   #27
Ouch
lol It doesn't sound like I have anything to worry about then. Extrordinary circumstances. I doubt I'll ever be in the same position he he. Glad that was all that broke though
08-20-2011, 03:45 AM   #28
@Respectedent
I have exactly the same configuration as you do and had a much similar problem with the 55-300.
Can you possibly send me a link or the contact you used at Pentax so I can get mine fixed?
Thanks!
08-24-2011, 08:41 AM   #29
QuoteOriginally posted by uchesn Quote
@Respectedent
Thanks!
You need to contact Lynn Badillo. See her number and email below. Good luck.
(720)988-2653
lynn.badillo@wildernestlogistics.com
11-10-2011, 10:46 AM   #30
Does anyone know if we can use the Metal mount instead of the plastic mount on the DA-L lens? If yes, will I need to order any parts other than 48000.M10801 ?
55-300mm, da, k-mount, kit, lens, mount, pentax lens, plastic, replacement, slr lens
*ist blurry viewfinder repair replacement korimako Maintenance and Repair Articles 4 11-11-2011 04:52 AM
Can the plastic lens mount on cheap Pentax lenses be replaced? creampuff Pentax SLR Lens Discussion 22 12-30-2010 06:29 PM
3-year extended warranty+repair/replacement for $300 for K-5 Eric Seavey Pentax K-5 23 11-26-2010 02:06 PM
*ist blurry viewfinder repair replacement korimako Pentax DSLR Discussion 3 05-28-2010 11:36 AM
Pentax K-mount Takumar 135mm f2.8 repair mopar_man Pentax SLR Lens Discussion 2 08-23-2007 10:47 AM
All times are GMT -7. The time now is 07:57 PM. | See also: NikonForums.com, part of our network of photo forums!
