Show Printable Version 10 Likes Search this Thread
05-16-2011, 05:22 AM   #196
DanielT74's Avatar
Hmmm... Why do people love the FA43 so much and there seems to be little love for the DA*55 given its faster speed, weather sealing and (cough) HSM?
05-16-2011, 05:30 AM   #197
TOUGEFC's Avatar
I can not answer that, but I do know for a fact that the DA*55 ranks very high on my lens next purchase list.
Also its diagonal FOV is 8 degrees narrower than the 43 and 8 degrees wider than the 77, making it the perfect fit between the 43 and 77. I want a WR 43 or 77, the answer is DA*55
05-16-2011, 06:23 AM   #198
hoanpham's Avatar
Can somebody post some more photos?
I am becoming addicted to this game ;-)
Here's another:
05-16-2011, 06:30 AM   #199
tackyat.2's Avatar
Is it a 28mm?
05-17-2011, 10:59 AM   #200
hoanpham's Avatar
QuoteOriginally posted by tackyat.2 Quote
Is it a 28mm?
Yes it is. Quite easy?
Who's next?
05-17-2011, 11:26 AM   #201
tackyat.2's Avatar
It was easy because I'm somewhat familiar with the 28mm focal length. I don't shoot with one regularly, but I do know how it affects perspective.
I'll go next:
Used flash, essentially straight from RAW.
05-17-2011, 01:37 PM   #202
Mamiya 55 1.4 ?
Eric
05-17-2011, 11:45 PM   #203
I'll go next:
seems like a telezoom. A Tamron 70-300, or the Pentax 50-200? wideopen perhaps?
05-18-2011, 12:01 AM   #204
hoanpham's Avatar
It's a K28shift. I had to shift almost max upward to get the perspective correct. It has typical K-lens CA/PF between highlight and dark. Sweet spot at f8 or f11.
Regarding your photo,
Looks like popup flash in relatively long distance to subject. I don't know which plant and left size, but guess, it's a 100mm or longer or a zoom, to have the bokeh like this. Color is quite monotone, so I can't see any typical color rending.
05-18-2011, 02:26 AM   #205
axl
axl's Avatar
I don't think it's as long as other guys call so I'll stick with 50/1.4
re: shift shot,
I thought it was a wide ish shift lens and K28 crossed my mind, but I didn't want to make a fool of myself...
05-18-2011, 05:06 AM   #206
tackyat.2's Avatar
Hint: It's a long prime.
The flash was a shoemount flash.
05-18-2011, 11:07 AM   #207
hoanpham's Avatar
I guess it is 200mm, one of the common long prime. Longer it would be point less to use flash. ~100mm would have some less bokeh, but also depends on distances. It can also be from a 135, I won't call 135 long. It would be easier if the photo contains some real life man-made subject.
Would you give a hint about distance to subject?
QuoteOriginally posted by axl Quote
K28 crossed my mind
It's just a game.
The K28shift has almost no distortion and distinct perspective when shifted more than 3-4 clicks.
Any more photo of the baby?
05-18-2011, 02:07 PM   #208
tackyat.2's Avatar
Understandable:
Distance to subject is very close, if not at minimum focus. The minimum focus on this lens is not what I call close, either.
It is an M42 mount lens.
05-18-2011, 03:58 PM   #209
DanielT74's Avatar
A Zeiss Jena 135mm? But the pic is not very sharp, so I am confused?
05-18-2011, 04:29 PM   #210
tackyat.2's Avatar
Nope, it's a 200mm.
Here's another example: this was definitely close to or at the minimum focusing distance.
k-mount, pentax lens, slr lens
Guess the lens - 1.4 and 1.7 50 vs 16-50 Egg Salad Pentax SLR Lens Discussion 8 10-11-2009 03:26 PM
Guess which pentax lens jackbullet Pentax SLR Lens Discussion 16 07-13-2009 06:21 PM
Guess the lens? bschriver11 Post Your Photos! 5 08-08-2008 04:26 AM
Guess the lens Mike.P® Pentax SLR Lens Discussion 8 07-23-2008 02:13 AM
Guess that lens! tybeck Pentax SLR Lens Discussion 27 05-29-2008 09:35 AM
All times are GMT -7. The time now is 01:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
