01-04-2011, 06:32 PM   #1
Lenses from RICOH KR-5
Hi
Will the lenses from ricoh fit my K-x.
I read its
Lens Mount: ''K" type bayonet with 65 rotating angle
Source Ricoh KR-5 manual exposure camera
Any feedback
01-04-2011, 07:00 PM   #2
Ole
Ole's Avatar
Yes, they will fit, but you have to watch out. Some Ricoh lenses have an extra pin which gets stuck in the camera's autofocus drive shaft and prevents the lens from being removed again. Check the lens for any such additional pin. If your lenses are the first generation Ricoh lenses then there is no such pin and no problem.
You can use them in the M exposure mode only since it looks like there is no 'A' setting on the lens. You need to set the appropriate option to allow use of an aperture ring in the Custom Function menu. Just change it to permitted and leave it at that setting also when you use DA lenses.
How to meter is explained here:
https://www.pentaxforums.com/forums/pentax-dslr-camera-articles/32-can-i-use-...td-series.html
k-mount, lenses, pentax lens, ricoh, slr lens
Ricoh XR Rikenon lenses with K-mount imadethis Pentax SLR Lens Discussion 4 10-07-2007 12:53 PM
When did Ricoh bodies and lenses STOP being compatible? scottax1 Pentax Film SLR Discussion 4 05-31-2007 03:04 PM
All times are GMT -7. The time now is 08:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
