Originally posted by joelovotti
Any thoughts to proper aperture for best depth of field without losing sharpness?
Here's what theory has to say (but I don' t see much effect in practice.)
Say your lens/camera combination becomes diffraction limited for normal photography at f-number N
diff.
Then for macro work the maximum f-number to use is about
N
diff/(1+m)
Because that's where diffraction will interfere with macro resolution.
The maximum macro DOF one might expect before diffraction interferes with resolution is close to:
DOF
diff ~ (N
diff/20m)^2
in millimeters, m is magnification
Say your lens is diffraction limited at f:20 under normal conditions. For maximum depth of field in a 1:1 macro with that lens you should set the f-stop to 20/(1+1)=10. You can expect a DOF of about (20/20*1)^2 = 1mm.
Say you must have a DOF of 1/4 mm. What is the maximum magnification you can use to meet this requirement? Solve the DOF equation for magnification:
m = (N
diff/20)/√DOF
m = (20/20) / √(1/4) = 2
Greater magnification may increase apparent DOF but it will also soften the "in focus" portion of the image. The "in-focus" portion will in fact be out of focus.
Dave
PS The above assumes that diffraction is limiting when the diffraction spot size equals the DOF's "Circle of Confusion."
