Quote: paperbag846: That goes for most of us
Agreed!
Quote: curious Peter: More choices?
Would you recommend the the 17-50mm over the 28-75mm? I heard that both are very good. But if I get one that starts at 28mm I will have an excuse to buy a 21mm Limited. Just to fill a "gap" you know.
I own and love them both--use each of them for different purposes. I shoot the 17-50mm as my main workhorse of my hiking adventures. The 28-75mm takes the family shots and other candid, poignant moments in life.
The answer to your question relies most upon what range is more important to you, but, if you do pick up a prime as you suggest above, then either lens will do. If it were me, I would opt for the 17-50/Da 70 mm combo--Yes, I defintely find the 70mm more special than the 21mm--I also find the Tamron 17-50mm more special than the 21mm.
Quote: curious Peter: Is this line of thinking an early sign of LBA?
Absolutely, with this thread we have a documented diagnosis now. TURN BACK!
