01-11-2011, 12:06 PM   #1
Reportage's Avatar
Whats good for ringside fights?
Considering the Tamron 17-50 f/2.8 and the Sigma 24-70 f/2.8
In this case, i was at ringside during a indoor muay thai novice tournament.
I used a Tamron 28-105 for the following but was too slow even at iso 6400. These are the shots that i like to take. Which of the two would be suited for my style of ringside photography with a K20D?
also are there any pointers for photographing MMA cage fights in harsh indoor lighting conditions?
01-11-2011, 01:30 PM   #2
sewebster's Avatar
k5?
01-11-2011, 01:31 PM   #3
paperbag846's Avatar
Because of the working distance I would go with the 24-70, but I have no experience with that lens.
You would do well with an external flash, pointed at the fighters, with a diffuser attached. It should help even out the light coming from above. I also would rely on TV mode.
If you can't use a flash... I'm not sure .
01-11-2011, 01:38 PM   #4
The HSM on the 24-70mm would be helpful. I would recommend the K-5...
01-11-2011, 09:05 PM   #5
Make sure you have some lens cleaning solution & tissue,gets sloppy at times.
01-11-2011, 10:15 PM   #6
SpecialK's Avatar
QuoteOriginally posted by BillM Quote
I was going to suggest a towel.
I think 24-70 might be the better option.
01-12-2011, 11:43 AM   #7
Reportage's Avatar
problem being whether i can use the 24-70 at f/2.8 or do i have to step down further in comparison to the 17-50 thats usually sharp even at f/2.8 wide open.
01-14-2011, 01:18 AM   #8
Reportage's Avatar
Tried the 50mm f/1.4 which is more then bright enough but too cropped when shooting ringside and in a lot of cases for some reason doesnt lock focus when subject is at the other side of the ring. The 28-105 did however.....something in th design?
01-14-2011, 07:51 AM   #9
FA 50mm 1.4 is not great for autofocus.
f/2.8, k-mount, pentax lens, ringside, slr lens, tamron
Whats a good upgrade lens for k-x? hockmasm Troubleshooting and Beginner Help 35 09-27-2010 05:35 PM
People So...whats good about this shot? D4rknezz Post Your Photos! 13 06-30-2010 09:31 PM
Pillow fights are a GOOD reason for weather sealed cameras inferno10 Post Your Photos! 10 02-19-2009 12:39 PM
Whats a good lens to get with tax rebate? tootal2 Pentax SLR Lens Discussion 8 05-15-2008 02:07 PM
whats a good + resonably priced teleconverter?? INcreative Pentax SLR Lens Discussion 20 01-09-2007 07:13 PM
All times are GMT -7. The time now is 01:53 PM. | See also: NikonForums.com, part of our network of photo forums!
