Originally posted by DMH I have SMC 18 - 55mm, SMC 50 - 200 and SMC A 50mm 1.7 with have 52mm, and 49mm filter ring sizes. Is an adapter available for my 50mm lens if I buy polarizing and ND filters for my zooms? And, if so, does the added distance of the adapter have any impact on the function of the filter?
Thanks, David
there are filter adaptor rings, and they usually permit stepping up/down in increments of 1 size, i.e. 49-52, 52-55 etc. Which might lead to "stacking the adaptor rings. There are also tools to separate filters from them. Maybe I should say were, I bought these 20+ years ago, Eventually I gave up and bought correct filters for each lens.
You need to be careful especially on wide angle lenses with them, they can lead to vignetting. You are now discovering the concept behind the pentax M series where as many lenses as possible used 49mm filters. To keep attachments the same.
