Originally posted by lkjr Should I compromise with the Sigma 70-200 that is supposedly soft above 150 for the focus speed?
My concern is that the reason for a 70-200 is that I will be using the top end alot...but if the pics are all soft there is that a good trade off? The Tammy 70-200 shots I've seen are spectacular through 200 but people say focus speed is slower and its nosier.
Great suggestions from everyone....thanks!
you need to do a little more research
I have the Sigma APO 70-200F2.8 EF (non DG non Macro) while I have heard complaints from owners of newer lenses about softness at max focal length, that is not an issue with the origonal version.
Look for one on the used market, they usually go for about $600, down from the $1200 when sigma had temporairly stopped making 70-200 lenses in K mount.
I also see someone mentioning the Tak 135F2.5 If this focal length is right, go for the K135F2.5 it is sharp even wide open and the extra 1/2 stop p[lus light weight makes it a great lens to use.
Others have mentioned a 50mmF1.4 if you can get close enough, another good idea.
Consider the math:
Image size = subject size * focal length / distance
your image will be either 16 or 24mm (the frame dimensions)
Subject size will be less than 1.5 meters (gymnists are little)
look at focal length and working distance and calculate what can work with what you can get.
