01-16-2011, 08:58 AM   #1
Focus speed: 43mm/1.9 vs 55mm/1.4
I'm thinking of buying another 43mm limited, as I miss it. If I remember right, it focused pretty fast for a film lens. Since I last owned it, though, the 55/1.4 came into being, and the focus speed was said to be disappointing to people. The two are comparably priced, and I already have an SMC Tak if I really, really need 1.4... So which lens focuses faster?
01-16-2011, 09:25 AM   #2
paperbag846's Avatar
I'm going to guess the 43 1.9 focuses faster from everything I have read.
01-16-2011, 09:32 AM   #3
dgaies's Avatar
QuoteOriginally posted by paperbag846 Quote
That is correct, the 43 focuses faster than the 55.
01-16-2011, 09:46 AM   #4
Is it true that the DA* 55 is actually slower than most SDM lenses?
01-16-2011, 10:06 AM   #5
dgaies's Avatar
I think I've owned all the SDM lenses at one point or another and if I had to guess at the order, I'd say it something like this:
(fastest to slowest) DA*300, DA*200, DA*17-70, DA*60-250, DA*16-50, DA*50-135, DA*55.
I might be biased on the DA*200/300 being the fastest because I seldom used them in bad light, whereas the 17-70 was probably used indoors some in more difficult light. Regardless of the exact order, the DA*55 is certainly on the slow side, and most likely the slowest.
FWIW, the focus throw on both the DA*55 and 50-135 seems to be about 135-150 degrees, where as the 16-50 and 60-250 is probably closer to 45 degrees. I no longer own the 200,300 or 17-70, but I imagine they had pretty short focus throws as well.
01-16-2011, 12:42 PM   #6
Thanks, all...that clinches it!
01-16-2011, 12:47 PM   #7
dgaies's Avatar
QuoteOriginally posted by mabelsound Quote
You're welcome. Both the 43 and 55 are fantastic lenses, and in practice the AF speed of the 55 isn't a really an issue for most applications. So even though the 43 has faster AF (on my K-5 at least), if you prefer the IQ, focal length and/or speed(aperture) of the 55 over the 43, I wouldn't let the AF speed play too big a factor in decsion.
01-16-2011, 03:09 PM   #8
They are really different focal lengths. I can understand comparing the FA 43 and DA 40, but the DA *55 is quite a bit longer (and faster) than the FA 43. I find the auto focus fast enough for most applications, although it isn't particularly fast.
01-16-2011, 04:50 PM   #9
I most certainly like the IQ of the 43, so that isn't an issue.
focus, k-mount, lens, pentax lens, slr lens
FA 43mm or DA 55mm or both? alfdog Pentax SLR Lens Discussion 19 05-26-2010 02:19 PM
For Sale - Sold: FA 43mm, DA 70mm, 18-55mm DA kit lens dreilly Sold Items 9 02-15-2010 12:38 PM
70 vs 77 auto-focus speed WMBP Pentax SLR Lens Discussion 32 10-24-2009 01:53 PM
K20d focus speed bessa66 Pentax DSLR Discussion 6 07-03-2009 04:33 AM
auto focus speed dafiryde Pentax DSLR Discussion 17 11-05-2008 12:33 AM
All times are GMT -7. The time now is 04:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
