10-06-2007, 08:09 PM   #1
raider's Avatar
Tamron 28-75/f2.8 with closeup lens?
Anyone used a closeup lens with Tamron 28-75/f2.8 before?
I am interested to know what is the result.
If I use a +3 closeup lens, can I get 1:1 macro?
10-06-2007, 08:34 PM   #2
FotoPete's Avatar
Just get some extension tubes. They won't spoil the quality of your 28-75.
Cuz close up lenses are essentially magnifying lenses and will cuz distortion.
10-06-2007, 08:52 PM   #3
Moderator Emeritus
I second FotoPete's opinion and the added benifit is you can use them with all your lenses that are suitable for macro work.
10-07-2007, 03:10 AM   #4
raider's Avatar
thanks for the tip.
There is this extension tube Extension Tube Macro Ring for Pentax dslr K100D K10D - eBay Nikon, Digital Camera Lenses, Digital Cameras, Lenses, Cameras. (end time 10-Oct-07 00:22:12 AEST)
Someone did comment before that this might not have the aperture lever so I might not be able to adjust the aperture from the body. Is this, nevertheless, still acceptable? I can't find an extension tube for the pentax mount with aperture level. Even if I do, I think the price might be exceedingly high and I could not afford it.
10-07-2007, 06:43 AM   #5
Moderator Emeritus
By the look of this unit you'd stop down Manually. That's not an issue really as long as the lens you use has an aperture ring, which yours does. Since most close up macro work takes a little time to set up. Tripod, manual focus and manual exposure. So you'd just leave the lens wide open and focus the scene. Then once that's done stop the lens down and set the exposure with the camera in manual. Takes a little practice but is easy once you're used to it. If you have a prime lens like any 50mm K mount you'll get even better results (sharpness) than the Tamron. I have this lens and it's very good but a good 50mm would be even sharper.
You might find the information on these earlier threads of some value as well:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/11161-answer-macro-question.html
Edit: BTW this set you found is a pretty cheap way to get started and I notice you have a 50mm f1.4 so you could be doing some decent macros fairly cheaply with either lens. (the advantage of the 50 is also that wide open it will be easier to focus as it is so much brighter)
10-07-2007, 05:23 PM   #6
raider's Avatar
Thanks Peter! Very well explained I must say.
k-mount, lens, pentax lens, slr lens, tamron
Ultra closeup by reversing a wide angle lens pentaxman Pentax SLR Lens Discussion 23 12-10-2008 06:43 PM
Help with closeup lens filters ctt Pentax SLR Lens Discussion 3 09-01-2008 05:39 PM
How to do the math for a closeup lens? raider Pentax SLR Lens Discussion 6 03-11-2008 05:57 AM
What closeup lens required to make the Tamron 28-75/f2.8 do macro at 1:1? raider Pentax SLR Lens Discussion 6 08-29-2007 11:18 AM
Wireless Remote & Closeup Lens ctt Pentax Camera and Field Accessories 4 06-18-2007 09:58 AM
All times are GMT -7. The time now is 10:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
