Quote: Pentax Bob: I got a reply today from Tamron about the 28-105 AF SP. They said it was not made in a Pentax mount. Also said it was replaced with the 28 -75 SP because the 28-105 did not work well with digital sensors. Looks like Sigma 28 -105 2.8 -4 is the closest available.
Bob, there is an Auto-focus Tamron, model 276D, 28-105 f 2.8 lens. Also, there is a Manual Focus Adaptall 2 lens, model 176a, 28-105 f 2.8. The former was discontinued in 2004, the latter in 2002.
In your opening post you labeled the lens you were seeking as this:
"It is a Tamron SP 28- 105 mm f 2.8 model 176 A." That lens is a MF lens, & is an Adaptall 2 mount--this means it wil fit all the major mounts, with the correct adapter. These are still available--I read about them now and then and, if patient, you can get one for your Penatx body--most likely used, but "new" ones surface as well.
However, the Tamron 276d AF lens, 28-105 f2.8 is another story. I suspect this is the lens about which Tamron responded to you on the phone. So, I have these questions for you:
Do you want the 276d model or the 176a model?
Do you really need f 2.8, constant, for the entire 28-105 range?
As others have said, the 176a lens is very pricey for a MF lens--surely there are better options. If you are very precise about your actual needs, there are many excellent people here who will point you in the right direction.
