10-07-2007, 03:53 AM   #1
Looking for low contrast lenses
As a theatrical lighting designer I often use my camera to take pictures of stage lighting, perhaps one of the most difficult environments to photograph well: often with obscenely large dynamic ranges.
So here's my theory I often read descriptions of "good" lenses as both being sharp and having high contrast, is this just another way of saying that it is sharp (micro-contrast, edge contrast) or is it contrast across the entire frame. If this is the case could a lens with "poor" contrast be used to compress the dynamic range of a photograph?
However I don't want a crappy lens, can anyone out there suggest some sharp but low contrast lenses (the wider the better) which might make my life a little easier when dealing with those difficult theatre shots?
10-07-2007, 06:32 AM   #2
Lowell Goudge's Avatar
Perhaps the issue is not the lens but the recording medium.
as a start, try shooting with different contrast settings in the camera.
Although I am not normally a proponent of RAW, this may be one time where shooting in RAW is a benefit, as it will give the best dynamic range.
I remember a very long time ago, (I think it was Ben) posted that he could see at least 9 stops of dynamic range when shooting RAW.
10-07-2007, 01:03 PM   #3
FotoPete's Avatar
Take lenses that are single coated. :P
10-07-2007, 05:20 PM   #4
roy
roy's Avatar
this should be easy.. just try out different numbers of layers of clear baggies stretched over the front of the lens..
this is just a stray thought so let me know if it works..
10-07-2007, 07:22 PM   #5
Abbazz's Avatar
QuoteOriginally posted by rdc Quote
Yes you can use lower contrast lenses to compress the dynamic range of a photograph with very contrasty lighting, like for example for stage photography or night shots. Old single coated lenses or lenses with many glass-to-air surfaces and early, low performance multicoating are often good candidates. Have a look at these dance photographs taken with a Canon 50/0.95 lens (10 glass-to-air surfaces), you will notice the very good rendition of the whole range of tones, despite the rather harsh lighting:
Web Catalog
Cheers,
10-07-2007, 11:56 PM   #6
imadethis's Avatar
How about shooting raw and merge to HDR with Photomatrix or Adobe's HDR, so this way, you won't need for a new lens, and you'll have a superior dynamic range.
10-08-2007, 01:34 AM   #7
rdc
I do shot raw, but HDR won't work beacuse actors have this annoying habit of moving between exposures.
10-08-2007, 06:59 AM   #8
jeffkrol's Avatar
I have a screw mount 55mm f1.8 Takumar that's a bit flat... Did you want to use manual focus?
10-08-2007, 08:42 AM   #9
Duplo's Avatar
Why not trying one of the tiffen Ultra contrast 3 filters, they should do what you ask I think.
io have not tried them myself, but I have a friend who loves it.
check the before and after pics from this link:
52MM ULTRA CONTRAST 3 FILTER - Tiffen.Com
Might be cheaper and more effective than a new lens
contrast, k-mount, lens, lenses, pentax lens, photograph, slr lens
Medium or Low Contrast Film Recommendations? Mister Pita Pentax Film SLR Discussion 7 04-26-2010 07:57 PM
Can K-7 use contrast AF (for video) with third party lenses? robjmitchell Pentax News and Rumors 2 05-21-2009 04:19 PM
Takumar 50mm F1.4 low contrast at narrow F-stops Slowpoke Rodriguez Pentax SLR Lens Discussion 13 11-28-2008 11:42 AM
Low light lenses smcclelland Pentax SLR Lens Discussion 3 07-05-2007 08:23 PM
Focusing in Dim or Low Contrast Lighting matix Photographic Technique 29 05-02-2007 10:25 PM
All times are GMT -7. The time now is 08:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
