Originally posted by pentup Please forgive the naive questions, but I was wondering, in regard to backups in case of failure:
Is it true that with older model bodies, SDM lenses can revert to screw-drive focusing? Rather than rewarding Pentax for bad lens design by buying more of them, could one perhaps use an old body as a backup -- assuming that screw-drive wouldn't be worse than manual focus for a given shoot, at least in an emergency?
You have to go back to the K100D or an early firmware version of the K10D to use the screw drive on the dual SDM lenses. But yes, in theory, you could do that.
Originally posted by pentup And, why is it that newer bodies can't use screw-drive in the event of SDM failure? Is it simply a firmware disability? Could the company at least salve the wound slightly by patching the firmware so people wouldn't suddenly be left with manual focus when they need AF?
Can't answer the question as to why Pentax won't allow this (I could speculate, but it would have no basis). People have been asking for this for a long time, pretty much since SDM lenses were released. It hasn't happen yet, and I would almost guarantee it isn't going to happen in the future. Not saying I wouldn't like to have the option as well, but I just don't see it happening.
Originally posted by pentup I was going to buy the DA* 50-135 since it gets such rave reviews, but as a hobbyist I simply don't want to deal with this warranty repair nightmare. And I don't want glass that, past its warranty, has lost a feature that accounted for much of its price to begin with.
I'm not sure getting the lens repaired is a "nightmare". If it's under warranty then it means going without your lenses for a few weeks while it's being repaired. If it happens outside your warranty, then it means the same wait plus some out of pocket expense. I wouldn't say the SDM motor accounts for "much of the price". A replacement motor, including installation by Pentax is on the order of $200-250 and from a authorized repair shop it's usually lower, closer to $150. Seeings as the DA* lenses range from $750 to 1200 new (in the US), in my mind it would certainly be worth fixing them if they fail vs using them as MF lenses or buying new ones.
