Welcome to the forum
C5k0 (hey is this an upgrade from C3PO .-)
Originally posted by xjjohnno ... The Russian lenses with an "A" in their series number have a removable and interchangeable mount held on by 3 screws, a lot like the T mounts but not quite the same.
Exactly. Loosen the 3 screws, turn lens 180°, done. Even better: Leave the inf. mark at 10 or 2 o'clock position, and you will be having more fun in actually using this thing on a DSLR. If you are into sunstars you might want to have the aperture blades aligned to the frame and adjust accordingly.
You might also check the real inf. on your system before. If it is way beyond inf., you could alternatively start building rings from thin sheet metal (masking foil and the likes) til you get the real inf. After that, adjust with the 3 screws to your liking.
BTW this lens is a copy of the CZJ Sonnar design, one of the best lenses you can get in M42 imo.
Cheers, Georg
