01-21-2011, 04:31 PM   #16
Pentaxor's Avatar
QuoteOriginally posted by yeatzee Quote
have any pictures with a background that will show bokeh attributes?
you mean like this?
I haven't been able to use the lens that much yet this year since I'm waiting to use it more this coming March. so images are quite limited as of the moment.
hope this helps for now.
basically, I'm impressed with the lens' rendering under certain environments with deemed harsh backgrounds (such as foliage, branches, fences, solid clutters, etc...)
01-21-2011, 05:23 PM   #17
paperbag846's Avatar
The samples from the A*85mm f1.4 have really smooth OOF... at f2. Like the DA*55 and FA 50, it is a *little* busy wide open. However those saymayng samples are pretty magical... tempting even.
01-21-2011, 05:27 PM   #18
dgaies's Avatar
This is just a quick test shot (that I happen to have uploaded) from when I first bought the FA*85/1.4, taken wide open at f/1.4, with a fairly challenging background (bokeh-wise).
01-22-2011, 02:56 AM   #19
axl
QuoteOriginally posted by dgaies Quote
thanks,
but sadly this rules the FA*85 out, judging by this, it doesn't seem any better than FA43 or 77ltds in the way it renders it's OOF stuff....
01-22-2011, 02:57 AM   #20
axl
QuoteOriginally posted by paperbag846 Quote
you have a point but I'm not buying f1.4 lens to use it at f2....
01-22-2011, 02:59 AM   #21
axl
QuoteOriginally posted by Pentaxor Quote
you mean like this?
Thanks for those too but again, not quite what I'm after... For example, the last shot with birdcage, the cage itself is still "very meshy" for my liking, one thing I like about K50/1.2 that it obliterates any detail in OOF areas smooths it out... and that's what I'm after but in longer lens...
01-22-2011, 03:12 AM   #22
axl
QuoteOriginally posted by Clou Quote
There are quite a few lenses to consider.
Here are some examples:
A* 85/1,4 @2,5
Red Dots - No Award
thanks but would you have any similar samples from the A* @ f1.4
I could be mistaken, but I was under the impression that the A*85 and FA77 were closer in design than the A*85 and FA*85.
I've always found the FA*85 to be very smooth, a bit better than the DA*55 and FA77. Not sure how it directly compares to the A50/1.2; perhaps a few test shots this weekend to compare them all? Do you have a suggestion for the best setup to be able to compare two lenses of different focal lengths? Inother words, would you frame the object so it was the same size or leave the distance from the camera to the focal point the same and just let the magnification be different?
yes, sorry, that was mistake on my behalf. I meant that A*85 and FA77 share the optical layout. FA* is different and doesn't have FREE, AFAIK.
with the tests, I'd appreciate it from you.
If I could be pain it the but, could I ask for both? i.e. shot from FA*85 wide open, followed by A50/1.2 wide open from the same spot, and then A50/1.2 wide open moved so the framing is the same. If you could do that for me, I'd be really thankful.
QuoteOriginally posted by macTak Quote
How about the legendary Bokina (either the Vivitar Series 1 or Tokina AT-X 90mm f2.5 version). It may not be as fast as you want, but it is a lengend for both sharpness and bokeh. In my opinion, it is the best macro lens for both sharpness and bokeh in the range. After all, it got that nickname for a reason.
You may also want to think of an even longer lens, which will help smooth out most backgrounds a little more anyway, like the K135/2.5, or dare I mention the A*135/1.8...
I was thinking of A8135/1.8 but they are very rare (in UK) and very expensive (1200 ish), the K135.... well, that one is still on the list
Peter,
why don't you try out the Samyang/Rokinon 85/1.4 ? the bokeh is buttery smooth. as Mactak mentioned, if you don't mind the S190/Vivitar 90mm speed (f2.5), it displays a great bokeh. the only downside though is that the 90mm macro is not that easy to find. so your best beat would be the Samyang.
the new Sigma is also great but I prefer the Samyang's bokeh better. also, the delay in the release for the K-mount is also a problem.
I see what you are saying but... they are not SMC... it might sound stuck up, but I'm real sucker for SMC glass! I don't know why.. well, maybe I do:
a) better flare resistance
b) better re-sale value
c) excellent build quality (those lenses I'm looking at... I mean you won't find badly build Pentax 85)
d) I like the "Pentax rendering"
call me silly but I fell for it...
QuoteOriginally posted by Mike Cash Quote
I have nothing useful to add, Axl, but I do want to thank you for not saying "bokeh".
pleasure Mike, I dislike the "bokeh" word usage as much as you do... people tend to use for whatever reason but for me it's OOF rendering.
01-22-2011, 04:17 AM   #23
Class A's Avatar
Probably too short but have you considered the K55/1.8?
01-22-2011, 05:46 AM   #24
axl
I have, and I might be getting one shortly, but that's for different reason. I like how it renders OOF areas wide open but it's far from smooth...
01-22-2011, 06:06 AM   #25
A lot of lenses smooth out nicely when stopped down a little (DA *55 which you have tried is an example). It is pretty tough to compare lenses that start at f2.4 -f2.8 to lenses that start wider than f2. From what I have seen, your 50mm f1.2 is about as smooth as it gets at that aperture.
The other thing you could look at, would be something longer, like a 200mm f2.8. Sure, it is only f2.8, but your depth of field is still pretty small due to a longer focal length. From what I have seen, both the DA * and FA * 200mm lenses are pretty nice with out of focus areas.
01-22-2011, 06:28 AM   #26
Mike Cash's Avatar
What does his height have to do with it?
01-22-2011, 11:55 AM   #27
Aperture isn't everything with the longer focal lengths...
A 50mm at f1.4 has roughly the same DOF as a 100mm at f2.8.
Also, the 85mm at f2.0 has less DOF than the 50mm at 1.2...
01-22-2011, 01:14 PM   #28
Pentaxor's Avatar
I understand what you mean Peter. although not bad for an f2.5 lens. and somehow as good or even slightly better compared to some fast 85mm. I believe f2 on that same. 90mm lens would have suffice what you are looking for.
I can't think of any fast telephoto that can display what you are looking for aside from the Canon 85/1.2.
01-22-2011, 02:06 PM   #29
macTak's Avatar
Especially with SMC. One can always go longer, as the telephoto compression will dramatically help to smooth out the backgrounds. That's why I suggested a couple of 135mm lenses; heck, there are also some excellent Pentax fast 200mm lenses, but that may be a bit too long for the OP.
Remember, distance between subject and background plays a huge role in how smooth the bokeh looks, so I wouldn't rush to judge any lens based on one or two pictures. Any lens, even the 50/1.2 (which I have) can be made to exhibit not smooth OOF by getting the subject/background distance "right".
01-22-2011, 02:08 PM   #30
A few more from different lenses.
Tamron 28-75/2,8 @75mm/2,8
Festgezurrt
A* 85/1,4 @1,8 far
Snow and Lighting
A* 85/1,4 @2,0 close focus
Gut befestigt
F 135/2,8 @f4,0
Griff
F 135/2,8 @f4,0
Beeren
OOF rendering depends on many factors, such as focal length, optical formula, number and shape of aperture blades, etc...
OOF is not my primary subject for photos and I usually stop down when usiing longer lenses, as the DOF is small anyway. There are lenses, that tend to have harsher OOF rendering (mirror lenses are good examples), others tend to have a better OOF rendering ('Bokina', Macro lenses, so-called portrait lenses), but most lenses can deliver good and bad OOF rendering depending on the subject and technical factors of the photo taken.
bit, k-mount, oof, pentax lens, slr lens
Nature Oof, oof, oof KarenH Post Your Photos! 7 10-30-2010 01:36 AM
Smooth sailing BjornAgain Monthly Photo Contests 0 09-18-2010 02:00 AM
Abstract OOF Rense Post Your Photos! 3 08-31-2010 06:35 PM
Smooth Snow Nitrok Post Your Photos! 13 01-24-2009 11:06 AM
OOF & nothing but the OOF! Akcelik Pentax DSLR Discussion 38 03-10-2007 09:53 PM
All times are GMT -7. The time now is 12:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
