01-25-2011, 01:24 PM   #16
Laurentiu Cristofor's Avatar
presumably in the middle of 2011 - Sigma added an optical stabilizer to it.
So they blocked the non-OS version to release the OS version for a system that has in-body OS? I assume optically it wasn't improved. Strange move.
01-25-2011, 07:48 PM   #17
Nick Siebers's Avatar
I've put an old pre-set Talumar 200/5.6 on a bellows, and while it won't go quite to 1:1 (I think) it gives me a heck of a lot of working space. But it needs a lot of light.
01-25-2011, 08:00 PM   #18
Digitalis's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
Strange move
bear in mind sigma don't just make lenses solely for pentax, they produce lenses for their own and many other manufacturers and not all of them have in body IS. From and economic point of view it makes sense, instead of having to manufacture parts for two different lenses( Is and non-IS version) they are consolidating into making just one lens.
01-26-2011, 01:46 AM   #19
RioRico's Avatar
QuoteOriginally posted by Nick Siebers Quote
Yup, that TeleTak takes a bit of daylight. Put a couple cheap sets of tubes behind it too, and you'll get to 1:1, with an effective aperture of f/11. The TeleTak is a good piece for this, because it's so light (410g) and sharp. Hmmm, maybe I'll try my Enna 240/4.5 on extension -- it's only 300g. But it won't have the same crispness as the TeleTak. It's hard finding sharp longer lenses that don't weigh a ton.
01-26-2011, 01:57 AM   #20
Wheatfield's Avatar
The pentax SMCP-FA* 200mm f/4 ED IF Macro is excellent for both 1:1 macro and distant subjects. However the Sigma 180mm f/3.5 suffers from image quality degradation when subjects approach infinity on the distance scale. At infinity, my sigma 100-300mm f/4 Zoom can beat the sigma 180mm f/3.5 at any aperture.
I find the bokeh of the FA200/4 Macro to be a bit busy (double image bokeh) at longer than macro distances, but it is truly stellar close up.
01-26-2011, 02:05 AM   #21
Digitalis's Avatar
I agree the effect is most prominent at f/5 and f/6.3 but nisen bokeh is in my opinion much more acceptable than a lens like the sigma 180mm f/3.5 which suffers from astigmatism at longer focus distances.
01-26-2011, 04:09 AM   #22
Class A's Avatar
You present your assessment about the Sigma 180mm as if it were accepted wisdom. Do you have any other evidence other than your own copy of which you cannot entirely be sure of whether or not it is OK? I know that your copy is great when close focusing but that doesn't prove the absence of a problem when focusing at something near infinity.
01-26-2011, 04:23 AM   #23
Class A's Avatar
QuoteOriginally posted by newarts Quote
For a 1:1 magnification (image size = subject size) the distance from the subject to the image is always four times the focal length.
Small typo. That should be "twice the focal length".
01-26-2011, 04:56 AM   #24
hoanpham's Avatar
Thank you all for this info.
I just ordered the book (Alfred A. Blaker).
I m happy, cheers.
01-26-2011, 05:56 AM   #25
Digitalis's Avatar
fair call, a sample size of one doesn't hold much water statistically speaking. But I am prepared to be proven wrong, I do know a few people who own the 180mm f/3.5 in different mounts..perhaps I can propose a temporary exchange.
01-26-2011, 06:17 AM   #26
No, the distance from the image plane (sensor) to the subject plane (called focus distance) at 1:1 is four times the focal length. The distance from the lens to subject (working distance) and lens to sensor are each 2 times the focal length at 1:1.
The minimum focus distance is always four times the focal length and it always occurs at 1:1 magnification.
The focus distance equation is:
Focus.distance = focal.length(1+m)^2/m ...........which is minimum at m=1
Dave
PS the above neglects the effective lens thickness which is the (positive or negative) distance separating front & rear principal planes.
01-26-2011, 05:44 PM   #27
Class A's Avatar
Your right, sorry.
I didn't pay attention to the distance you were defining and assumed you were talking about the "working distance", not the "focus distance". Hope your clarification didn't help only me.
01-26-2011, 05:45 PM   #28
Class A's Avatar
...I do know a few people who own the 180mm f/3.5 in different mounts..perhaps I can propose a temporary exchange.
That would be useful, thanks in advance for considering this.
I googled a bit, trying to find support for your statement, but couldn't. Doesn't prove anything, but at least it doesn't seem to be an obvious and common problem.
01-27-2011, 01:32 AM   #29
Digitalis's Avatar
When I am dealing with distant subject matter, grabbing my macro lens is the last thing on my mind - It's nice to see my biases are shared by the consensus.
In years past it was not uncommon for macro lenses to be poor at distant focus settings. I will point out that mine is the non-DG version, but even that fails to explain the poor performance at great distances.
though I have to say, does this look like an image from a defective lens? I'm not sure if you can tell by looking at this image, but you can see the stomas in the leaf. Stomas are cellular respiration holes that are practically invisible to the unaided human eye unless viewed under a microscope, or a very good camera lens.
01-27-2011, 01:45 AM   #30
Class A's Avatar
Yes, but floating focusing designs put an end to that and the one in yours could be responsible for causing trouble at infinity focus. In other words, with a moving group that is meant to adjust its position depending on focusing distance it could very well be that the lens excels at the MFD but is poor near infinity focus.
Of course this is just speculation but I think it is fair to say that great close focusing performance doesn't prove that the lens is completely in order with floating focusing designs.
P.S.: Nice image and great lens performance!
k-mount, lens, macro, pentax lens, slr lens
Macro performance on long vs. short lenses harmonica2 Pentax SLR Lens Discussion 14 03-20-2010 10:22 AM
100mm range Macro lenses - Cant Decide! PentaxScott Pentax SLR Lens Discussion 37 01-11-2009 10:53 AM
Long range lens suggestion vizjerei Pentax SLR Lens Discussion 26 10-27-2008 05:49 PM
Cheap, long-range telephoto lenses any good (how about prime ones)? bjsmith Pentax SLR Lens Discussion 35 06-21-2007 10:53 AM
Why long range lenses for landscape shots? Photochop Pentax SLR Lens Discussion 5 04-03-2007 07:09 PM
All times are GMT -7. The time now is 06:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
